Home > Technical (L322) > L322 4.4 TDV8 faulty oil level sensor
Page 2 of 3 <123>
Baltic Blue
https://www.fullfatrr.com/forum/topic46960...oil+sensor
I’ve found this post, but it’s an L405 v6, but it finishes by saying the 4.4 sensor is easy because it is external.
Cost c£70 ?
Post #504862 11th Feb 2019 9:43pm
rjff
If this helps, dash message with cold engine and bonnet shut and working level indicator.
Also, if your battery is getting wet, there is a scuttle drain pipe which should be fitted to the bottom of the drain, indicated with a yellow circle. This takes water away from the batttery. Also perhaps seals around engine bay leaking in that area.
 Cheers
Richard
Gap IIDBT
Post #504897 12th Feb 2019 1:02pm
rjff
Pic of sensor location, obviously upside down
Just caught your other thread, and I think Mike's (Baltic Blue) and Stan's ideas of fuses and voltage should be your first port of call.
If your battery is getting wet, a thorough clean of all contcts/connectors in that area may help. These beasties are easy prey for electrical gremlins. Cheers
Richard
Gap IIDBT
Post #504914 12th Feb 2019 5:00pm
Baltic Blue
Thanks rjff that is the picture I was looking at last night but was unable to post because I am using an internet connection so slow I think it must be via carrier pigeon,
but now other symptoms are being discussed like temperature sensor, wet battery.... it’s time to get the AVO out and the wiring diagram. Bow down
Post #504916 12th Feb 2019 5:20pm
rjff
Ahh Mike
Another man with an AVO Bow down Thumbs Up
I tried rotating the image of that sensor, wow, it looks just like those always ascending stairs. Cheers
Richard
Gap IIDBT
Post #504917 12th Feb 2019 5:39pm
edward19
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
A big thanks to everyone for helping me. The pictures and suggestions are a great help. With regards to the water leak the drain channel in the top right hand corner, adjacent to the wing is unblocked. However when it rains, the water runs over the top of the gully in the trim and onto the battery. Any suggestions on how to remove would be great.
Post #504918 12th Feb 2019 5:40pm
rjff
Edward
In my photo you can just see the drain tube in the dark recesses of the battery compartment. Make sure that is properly connected to the bottom of the drain fitting circled and is not blocked somewhere along it length. Mine was, and let the water build up until it overflowed onto the battery. I used a strimmer cable as you would a drain rod. Worth checking the driver's side too. Cheers
Richard
Gap IIDBT
Post #504919 12th Feb 2019 5:47pm
Baltic Blue
rjff... my dad bought me an AVO 8 as a gift for passing my C&G full tech, and it is still in regular use nearly 50 years on.
Best meter ever... Thumbs Up
Post #504920 12th Feb 2019 5:51pm
rjff
Mike Thumbs Up
Edward, let us know how you get on, and if we can help further we will. Cheers
Richard
Gap IIDBT
Post #504921 12th Feb 2019 6:12pm
edward19
I sure will. At the moment it doesn't run!!. However I did buy it like that. Don't ask!
Post #504923 12th Feb 2019 6:22pm
GGDR
Did you sort this Edward?
The dash pic you posted oil level unavailable is normal, you have to wait 10-15 minutes for the oil to settle before it will give you a read. Or did you work that out?
. Cheers, Greg
Post #505961 21st Feb 2019 10:20pm
edward19
Hi
I've only just received the fuel pump back this afternoon. It took nearly 2 weeks for a fast service!!! I managed to plumb it in and try just before it got dark. The air suspension came up and the vehicle moved a few inches back and forth but I then shut it off for the night. I'm planning to take a look at the oil level sensor next and check the fuse etc. I was keen to make sure nothing was missing from my car (except the engine cover!!!) and ran water down the drain hole in the top RH corner.
Thanks
Post #505964 21st Feb 2019 10:27pm
edward19
Water on battery
Hi All
I've done a test overnight and after clearing the drain hole in the top right hand corner of the scuttle, I put some kitchen towel in the recess where the battery goes. After a small rain shower overnight the tissue is soaked. I've posted a photo of the area and hopefully everyone can see that there is a definite gap between my trim panels running along the front of the scuttle and the wing. Any ideas as to what is happening?
Also my fuse 20 for the oil sensor is ok so I will be taking the sensor out soon
Post #506016 22nd Feb 2019 1:01pm
rjff
Edward
This is a photo of the area on my FF. I have no leaks onto the battery, even when jetwashing the car.
There doesn't appear to be any great difference in the seal positions. I can only add that there is a tube connected under the hole pictured and mine was blocked. Have you checked that and run water down the hole? Sorry to repeat myself Confused but also checking no one has broken the short spigot under the drain hole is worthwhile. Forgive me if you already have. Other than that, possibly the seals are failing. Cheers
Richard
Gap IIDBT
Post #506035 22nd Feb 2019 3:58pm
edward19
Hi Richard
Thanks for the picture. It looks almost identical to me, which is weird. I've used a small funnel and poured water into it, which then ran down somewhere between the inner wing and the plastic surround (I think). Do you think the seals have lost their compliance? The one on the wing further toward the front of the car is knackered.
Thanks
Post #506046 22nd Feb 2019 5:47pm
Page 2 of 3 <123>
