Home > Wheels & Tyres > General Grabber AT3 255 55 R20
Page 2 of 8 <12345678>
Harlequin
United Kingdom 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Just fitted these on my L322 SC, and very pleased with the choice.
They are quiet, cheap, and look the business .
Also a thumbs up for tyre fitter AJS Tyres, near Reigate. Specialise in 4x4 and they all drive Rangies or Discos. It was interesting to note that they were all running on AT3s
Post #498680 15th Dec 2018 7:49am
AndrewM
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
For the record and after a few concerns & 2nd thoughts - I've just fitted GG AT3's ( 255/55/r20) to my L322 (MY2010) & very pleased & thoroughly recommend them to others wondering whether to go for them,or not?
My reason on buying is that I needed new tyres anyway and the current Pirellis are useless on grass, mud and any snow+ I was also looking at taking it skiing next season.
I had an XC90 before & fitted it with Nokians. These were very good, but hadn't seen any L322 reviews on using these tyres and were also more expensive.
Only slight downside with AT3's is the spare is a snug fit & i have only partially inflated it. The car sits just slightly higher ( you would only notice if you'd owned the car for a while or knew your L322's)
But feels a better, smoother ride than the OEM Pirelli scorpions & cheaper to buy. No noisier than Pirellis either.
Post #508496 12th Mar 2019 10:59pm
DrRob
Andrew - got any piccies you can show us?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #508538 13th Mar 2019 10:45am
grey17
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
Hi guys.
I run 32psi all round on my car, 275/45/R20 on an RR Sport. The higher psi figures for rears assume you'll be driving with a boot full of heavy luggage and for the most part, it is totally empty.
The car feels much more balanced now and when you go over bumps and pot holes, you have the same "feel' from front and rear and is much smoother.
Also, if you stand back and look at the sidewall bulge, it is now the same front and rear.
Don't forget that once you have heat from your brakes and driving, the pressures increase with temperature.
G
Post #509181 19th Mar 2019 12:59pm
rafman
Australia
Anyone running these on a L405? If so what do you think of them? L405 SDV8 Autobiography (MY13)
Post #509185 19th Mar 2019 1:37pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I have been running General Grabber AT3s in 255/55/20 on my L405 all winter and they have been excellent. I have been on shoots and other off-road locations which were beyond the capabilities of the OEM Pirellis. I have not noticed any downside. Certainly no increase in road noise.
I will probably but the Pirellis back on for the Summer to keep the AT3s with as little wear as possible so that they are as good as can be next winter.
Post #509201 19th Mar 2019 3:21pm
grey17
They are not Winter Tyres!
Post #509202 19th Mar 2019 3:30pm
martinf
I am not after winter tyres. I need tyres to get me across muddy fields and they do that very well.
Post #509209 19th Mar 2019 4:10pm
topgeartowers
I got the car with 36 all round, changed to 34/36 as per door shuts and felt the car dived a bit more under braking. Will be going back to 36 all round!
Post #509222 19th Mar 2019 6:28pm
grey17
Thats good. It sounded from the way you'd written your comment that "WInter" implied driving on snow and compacted snow.
Post #509227 19th Mar 2019 6:47pm
grey17
It does make a big difference to have the pressures on all four the same. Funny as they always have the lower pressure at the front where most of the weight is and always struck me as counter intuitive once you know that.
G
Post #509228 19th Mar 2019 6:52pm
martinf
Actually they have M+S and the 3PSMF symbols on the sidewall. The Goodyear website says:
"True winter tires, carrying both M+S and 3PSMF markings, make an important safety contribution in winter conditions, particularly for cars and vans"
So I think they are winter tyres and are suitable for use in snow even though that is not my main requirement.
Post #509265 20th Mar 2019 9:07am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
If anyone has a pic or two of the 55 profile Grabbers on an L322, would you mind sharing? I'm approaching the point when I need new tyres but I'd like to see how they look in real life on a car, rather than just a pic of the bare tyre on a website.
Post #509266 20th Mar 2019 9:17am
grey17
Unnecessary quote removed
There is a big difference Martin but if your AT3s work well for muddy tracks and fields then thats fine but, having a Mud and Snow marking and 3PSMF does not make it a true Winter tyre. Winter tyres have many more sipes than an AT3 and the compound structure of the tyre is different.
My General Grabber Snow Grabber Plus have hundreds more sipes than an AT3 and the harder rubber of the AT3 make them fine to drive on during the summer months. Winter tyres are generally too soft for summer driving.
M+S & 3PSMF makes them more of an All Season but not a specialist Winter tyre.
Post #509287 20th Mar 2019 11:01am
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I’m currently running these at 36 psi all round and can’t fault them.
 Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #509475 21st Mar 2019 6:30pm
