![]() | Home > Maintenance & Mods (L322) > xenon 6000k |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35860 ![]() ![]() |
i fitted some hid 6000k bulbs over the weekend and they look a bit more bluer than the 4300k OE bulbs, well chuffed...not a very good pic [one replaced] but hopefully you'll see the difference.
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
you can def see the difference Stan. The one of the right of the pic is loads better |
yep, I did mean the one of the left |
yep, sides upgraded as well..
where did you get those from stan? easy to fit? FFRR TD6 HSE
got them off ebay and a piddle to fit.. ... - .- -.
these look different
those are the old type leds , you need the newer 'smd' type , sort of little yellow button type leds.. ... - .- -.
thanks mate.
nice ones here for fogs
no problems with errors, in fact its quite cool seeing the sides flicker when the ecu does its check on startup.. ... - .- -.
i have leds in my inner halogens as well dave but use them as drls...the inners are crap as only 10 volts is fed to them thats if you have bi-xenons btw... ... - .- -.
hi my ones look ok,as i say they dont throw much light out but the bi xenon's will do that.. V8 facelift Range Rover Autobiography 22" wheels.
