Home > Technical (L322) > Sun roof adjustment
Page 2 of 4 <1234>
robkuijpers
Netherlands
All
YES, it also worked for me! Remember to put the sunroof in tilt position and then hold it for about 30 sec, wait for the clunk and its done.
Priceless, the knowledge sharing in this forum. Can't beat the official dealerships focussing only on selling new Chelsea Tractors 😀
KR
RK 2012 RR Vogue 4.4 TDV8 Sumatra Black
2004 Defender 110 Td5 Epsom Green, 'Alive' Chip tuned and a Warn 8274 Winch
1978 Citroen Mehari Orange Kirghise
2001 Defender 90 Td5 Softop (gone)
1992 RR Classic 300TDi 'Soft dash' Green (gone)
1989 RR Classic V8 Caspian Blue (gone)
Post #515162 13th May 2019 8:30am
mat10
Just picked up my new to me Range Rover, and discovered our sunroof was down at the back as well, so tried the above and worked for me as well..... THANKS
Post #516038 21st May 2019 7:31am
DrRob
Confused. One post says cycle from open to close and hold for 30s in each position and another post says start from tilt position Confused Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #516050 21st May 2019 8:39am
Springer
United Kingdom 2003 Range Rover Vogue Td6 Galway Green
Also tried this and worked for me too no more wind noise
Post #516081 21st May 2019 2:08pm
Blueboy1
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Worked for me too Very Happy Thumbs Up Top Club
Post #516206 22nd May 2019 7:05pm
DrRob
From the owners manual page 45:
“Note: If the battery is disconnected or the power supply is interrupted while the sunroof is partially open, it will need to be recalibrated as follows: With the power supply reconnected, fully tilt the sunroof open. Continue to push the switch in the tilt position for approximately 20 seconds. The sunroof can now be operated as normal.”
Also on page 209
SUNROOF RESET
If the battery is disconnected or the power supply is interrupted while the sunroof is partially open, it will need to be recalibrated.
When the battery is reconnected or the power supply is restored, recalibrate the sunroof as follows:
1. Switch the ignition on.
2. With the sunroof closed, press and release the front of the switch. The sunroof will move to the tilt position.
3. Press the front of the sunroof switch and hold for 20 seconds.
The sunroof can now be operated as normal. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516209 22nd May 2019 7:59pm
dazza1983
I’m kind of confused by this post
What’s the issue that people are having??? The sun roof doesn’t sit flush with the roof?
Then you just re calibrate it via the switch?
If the sun roof isn’t sitting flush to start with does this mean it’s not closing properly?? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #516250 22nd May 2019 11:40pm
DrRob
Daz - correct. Some folks sunroofs don't fit flush. Mine is slightly down at the rear.
Time to press "the button" Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516274 23rd May 2019 7:13am
dazza1983
Let me know what happens when you do mate.
I think mine is down at the rear also. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #516278 23rd May 2019 8:30am
dazza1983
Did mine just this second had now made the sunroof sit ever so slightly proud of the roofline like it’s supposed to be. You can see that the velvety material surrounding the glass has almost got a dirt line where it was sat low
I’m thinking this may be something that needs to be done every 6 mo this or so.
Wonder why it’s starts to sit lower than it should?? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #516353 23rd May 2019 6:49pm
DrRob
Mine now level Thumbs Up
Owners manual plus Forum = Bow down Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516354 23rd May 2019 6:55pm
Andykid77
United Kingdom 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
When i bought mine i didnt even notice the sunroof was low at the back....drove 120 miles home in the pouring rain Big Cry
Later that evening i was looking out of the bedroom window and wondered what the marks round the sunroof were....went down and found gaffer tape residue all round it Censored
I guess the previous owner didnt bother working out the problem and just taped it up to stop water leaks..
A quick search on here found the simple answer and all is good with the world again! Very Happy
Post #516962 30th May 2019 3:47pm
DrRob
Power of the forum Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516974 30th May 2019 4:34pm
dazza1983
Is my sun roof suppose to have a bump in the seal at the rear???
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #516984 30th May 2019 9:19pm
bishbosh10
So the reset from tilt position worked for me but when I fully open and then close the sunroof it still sits low. Tried the fully open for 30 secs and then fully closed for 30 secs and that made no difference.
Any clues or other avenues to explore please? Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #564317 12th Aug 2020 2:27pm
Page 2 of 4 <1234>
