![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Go for it ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Thanks |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3560 ![]() ![]() ![]() |
I know, I was staggered at the claimed accuracy.
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
Hello Everyone,
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Hi, Guys, I am getting the yellow triangle DPF full 4 times in 4 weeks I have done a lot of towing with the tintent and only get it after sitting in traffic, I think it could be the DPF regen sensor I have cleaned the MAPT sensor I am hoping it`s not a clean up job on the exhaust DPF< Do you think I am on the right lines? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
Tinman,
Spitfire S,
SpitfireS I think any cleaning on-site won't be as good as if you go somewhere.
gonna_go_double_r - With 'on site' I meant their workshop.
Hi, GGD,
Hi Tinman,
Changing the manifold sensor for me didn't do anything other than removing the error code. Have you checked your donut hoses? That's the intake circular plenum which sits atop of your engine. There are four flexi hoses that feed into it and these can crack and I remember one member was towing in France and had a lot of trouble. But he was getting Restricted Performance and DPF yellow then red. I'd remove and carefully check all four hoses for cracks. You might need to stretch them to properly check for cracks. It might not be this but it'll cost you nothing but an hour. See page one for the details of who I used. Before you do that, suggest you invest in an IIDTool because, as Mike said I think earlier you really need to see what's happening both from a grams soot level and also that regens are happening properly. Have you taken it for a steady 50mph drive without the caravan? And are you getting the yellows only when towing? Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
GGD
Any news on yours Matt?
Matt,
