![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Turbo Twin Oil Drain Pipe Modification - DIY? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Fantastic Graeme, thanks for your thoughts!
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2674 ![]() ![]() |
Sorry, I was referring to the original method which I would not do myself but I shouldn't have made any reference to it.
This is a pic mid-drain mod from another thread I saved.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
It was me that posted the pictures!
AH yes I remember now AJG!
No problem, any time. BMW i3 Electric Car
Yes, that is the diff bolt. However the original pipe's bracket bolt would be a better option.
Flipped, although it's pointing down and not up like the ones on the left:
This TSB is for 2010-2012: https://www.fullfatrr.com/gallery/albums/u...20Smke.pdf
LTB00524V6 is for the L405 MY13/14 although I don't have an English version. I can look at the pictures though and they're all the same as the L322's. |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Looking at the later pipe and the one Int the TSB, looks like the block has been modified, the tsb pipe has the o-ring in the same place but then has a long tube with a retaining thread at the end suggesting the oil galleries are different and the tsb item is bridging a gap? |
The factory drain's new sump fitting could easily be the same size as the plug whereas the retrofit's long tube is needed to reach past the larger plug diameter. The later sump must have a threaded hole for the retaining bracket to bolt to. |
I'm thinking Graeme, looking at the fitting being threaded deep in the hole, that the drilling can't be avoided.
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 103 ![]() ![]() ![]() |
Looking at the 405 pipe it has 2 o ring seals and the mounting bracket looks like it's secured to the bolt hole adjacent to the blanking plug , if so it may well just go straight in if the plug is removed and be held in by the bolt through the bracket , the only unknown is if the oil gallery is directly behind the plug or not . |
