Home > Maintenance & Mods (L322) > 4.4 TDV8 Turbo Twin Oil Drain Pipe Modification - DIY?
Page 3 of 5 <12345>
GraemeS
Australia
Perhaps the later drain could be used with its bracket bolted to a stepped bracket from under the diff bolt, thereby not needing to attach a bracket to the tube. This would very much simplify the fabrication required.
Edit: This assumes that the turbo is the same as the L405's secondary turbo or at least has the same drain attachment point so that the drain otherwise fits. I can't remember which turbo is different between the 2 vehicles although IIRC the primary turbos are slightly different whereby the L405's fouls the L322's body, as noted in the thread for a new 4.4 being fitted to an L322.
PS. I'd do this mod myself but not drilling and and tapping and hope to get away with only removing the front driveshaft to the diff.
Post #520118 30th Jun 2019 11:48am
GGDR
Fantastic Graeme, thanks for your thoughts!
Yes I believe you are correct about 405 turbos fouling from Salter's re-engining project.
Could you pls elaborate on your last sentence? If you did it yourself, you'd not drill....
EDIT: do you mean trying to find a way of securing the later 405 pipe with it's push-fit?
. Cheers, Greg
Post #520122 30th Jun 2019 12:11pm
GraemeS
Australia
Sorry, I was referring to the original method which I would not do myself but I shouldn't have made any reference to it.
Yes, I envisage that I would readily make a simple Z bracket to bolt the the L405 bracket, which appears to hang not quite vertical from the push-in fitting.
Post #520136 30th Jun 2019 1:00pm
GGDR
This is a pic mid-drain mod from another thread I saved.
(can't remember which one, thanks to whoever posted Thumbs Up )
You can see the replaced lower plug.
You can also see the fitting screwed into the newly tapped hole.
To the left - is this the diff bolt you mean Graeme?
Here's another angle before they have taken the blank plugs out:
And here are all three pipes:
From Left: Original. TSB Mod (version 1) Revised/405 (version 2)
Shame the 3rd is facing the opposite direction
. Cheers, Greg
Post #520144 30th Jun 2019 2:43pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
It was me that posted the pictures!
Here are all of the pictures from Green Oval when they did mine (if I can get them to load).
 BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #520151 30th Jun 2019 3:47pm
GGDR
AH yes I remember now AJG!
Thank you for posting all these additional pics.
Greg Cheers, Greg
Post #520155 30th Jun 2019 4:57pm
AJGalaxy2012
No problem, any time. BMW i3 Electric Car
Post #520156 30th Jun 2019 5:01pm
GraemeS
Australia
Yes, that is the diff bolt. However the original pipe's bracket bolt would be a better option.
Can you do a mirror image of the later pipe to get it pointing in much the same direction as the others?
Post #520188 30th Jun 2019 9:50pm
GGDR
Flipped, although it's pointing down and not up like the ones on the left:
Although a closer look at the fitting of the - let's call it Mk 1 kit - and I noticed the thread is far inside. The bung surface ID is sealed by the o-ring on the fitting.
So maybe there's no way around drilling?
Page 10 of the TSB says:
Using a suitable drill and a 12mm drill bit, drill through the centre of the drill guide in to the oil pan until the drill bit breaks through the inner wall of the oil pan, (resistance will no longer be felt on the drill once the inner wall has been broken through).
. Cheers, Greg
Post #520191 30th Jun 2019 10:35pm
GGDR
This TSB is for 2010-2012: https://www.fullfatrr.com/gallery/albums/u...20Smke.pdf
I'm interested to look at the revised version for the early L405 SDV8. Does anyone know how to get TSB's ?
. Cheers, Greg
Post #520199 1st Jul 2019 6:28am
GraemeS
Australia
LTB00524V6 is for the L405 MY13/14 although I don't have an English version. I can look at the pictures though and they're all the same as the L322's.
Post #520208 1st Jul 2019 8:39am
ur20v
A Trap
Looking at the later pipe and the one Int the TSB, looks like the block has been modified, the tsb pipe has the o-ring in the same place but then has a long tube with a retaining thread at the end suggesting the oil galleries are different and the tsb item is bridging a gap?
Post #520212 1st Jul 2019 10:31am
GraemeS
Australia
The factory drain's new sump fitting could easily be the same size as the plug whereas the retrofit's long tube is needed to reach past the larger plug diameter. The later sump must have a threaded hole for the retaining bracket to bolt to.
Post #520219 1st Jul 2019 11:38am
GGDR
I'm thinking Graeme, looking at the fitting being threaded deep in the hole, that the drilling can't be avoided.
Does that deeper wall in the sump need to be opened to let oil through.
The big question is: if you just removed the plug, is there oil in that gallery?
If not then the drilling is to both let oil through and also to allow you to tap a thread.
(As opposed to just needing a hole in order to cut a thread).
Note the o-ring seal on the outer ring.
. Cheers, Greg
Post #520770 5th Jul 2019 6:48pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Looking at the 405 pipe it has 2 o ring seals and the mounting bracket looks like it's secured to the bolt hole adjacent to the blanking plug , if so it may well just go straight in if the plug is removed and be held in by the bolt through the bracket , the only unknown is if the oil gallery is directly behind the plug or not .
Post #520784 5th Jul 2019 8:59pm
Page 3 of 5 <12345>
