![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
| Dr richie_poor Member Since: 05 Jul 2019 Location: Ballarat Posts: 4
Firstly having spent the last hour reading this thread I feel much more up to speed on DPF issues - thank you so much to all especially Greg
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Matt that fill rate does not sound great. |
Hi Matt
Hi Greg
Just for clarity -the IID will not clear a red and/or force a regen
Hi again Richard,
| Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279
[quote="Matt M"] My wife pointed out a normal person without an IIDTool and a preference for perfection would not even notice this![/b]
Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
I did a three month trial using 2 bottles of this additive to supermarket diesel.
Thanks Greg
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
i thought it was the heat generated by the exhaust that is the main factor for dpf regen not the speed of the vehicle...am i wrong? ... - .- -.
Well Matt that's an interesting turn! We should talk! I'm wondering if they did any software update? Sounds like a hack.
I do think the EGR valve could be a contributor to a too-fast-filling DPF.
(Meaning the valve should be fully closed, but crud prevents it closing properly) Needs more actual research, but I'd bet hard cash notes my EGR and well whole intake system - has some clogging. Perhaps it's not closing properly. If the throttle body is clogged too that may affect things as equally. It's the mix of o2 vs exhaust gas that both of these control. And that mix (o2 vs exhaust gas) also affects soot production - (I am right on this?) What do we think? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Matt,
