Home > Technical (L322) > DPF full. see dealer message out of the blue.Sensor failure?
Page 1 of 4 1234>
Dolphinboy
2011 4.4 TDV8.
Driving today down motorway to bristol and at end of motorway red triangle warning “dpf full - see dealer” pops up. Car has been 100%. Last yellow dpf warning was in May 2019 but went out after regen. Parked up and went about business. When I got back in no warnings. Then on driving home later in the day, red triangle warning reappears and then yellow engine light and restricted performance. Made it home (10 miles). Car doesn’t smoke at all and second turbo gets a good work out every so often (again no smoke)
Don’t understand why no prior warnings (yellow dpf triangle) at all. Car does a mix of urban day to day with a 10 mile 35 minute commute along dual carriageway and motorway.
Thinking it is prob EGT sensor or dpf sensor. Poss throttle body? Waiting. For my IID to arrive next week for faults.
Anyone any thoughts? I don’t believe it could fill up so fast without any warnings.
Ps anyone in bristol care to lend me an IID until mine arrives? Bow down
Post #530698 12th Oct 2019 8:05pm
GGDR
Donut hoses are common. Search you'll find loads.
Or another boost leak - i.e. pipework.
I wouldn't drive it. Plus the IID won't clear a RED DPF warning.
But you do need to check for any other errors.
See my DPF mega guide.
. Cheers, Greg
Post #530699 12th Oct 2019 8:27pm
DrRob
As Greg said. Don’t drive it. Get it to a good independent specialist ASAP to read codes and work out what’s wrong with it. It’s usually not the DPF itself but other issues like Greg mentions.
Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #530700 12th Oct 2019 9:30pm
Dolphinboy
Thanks guys. I have spent most of today reading all your excellent posts ( Bow down ) and have come to the conclusion that it is not being allowed to regen due to a sensor failure. Either EGT, or throttle body or some other?
It seems highly unusual to suddenly get a red pop up do you agree?
Will get a fault reading done ASAP then a smoke test on the hoses.
Will relay back my findings and thanks again all of you for your comprehensive info. Bow down Bow down
Post #530705 12th Oct 2019 11:11pm
GGDR
I guess it's possible.
With mine recently, aside of my usual fast-filling DPF due to London traffic, I had an issue which gave me restricted performance which then led quickly to a red DPF. A double cause of my restricted.
https://www.fullfatrr.com/forum/topic52807.html
The IID faults codes kinda sent me around the houses until I found the culprit, a loose intake hose. Under boost, if these leak it will throw a restricted, sometimes without an error code and it will most times fill your DPF to red, effectively giving your two causes of restricted at once.
Air system leaks do cause the DPF to fill very fast.
So yes whilst your theory could be correct, don't underestimate the basics - which on the 4.4 are the donut hoses (or another intake hose leak e.g. in my case) Cheers, Greg
Post #530710 13th Oct 2019 8:40am
DrRob
Have you got a decent independent specialist around you?
Cam Tech Craig is not too far from Bristol...
https://www.cam-tech-landrover.co.uk/contact-us/ 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530712 13th Oct 2019 9:06am
GGDR
Oh also dolphin, again on the best-to-eliminimate-the-basics logic:
- it won't regen if fuel is 1/4 or below.
- driving speed & traffic - the ECU can be fickle so best to sit on 50 with the cruise on. no need for revs or low gears
These won't help now you're on red but if say on your last motorway/50mph run your fuel was low, might be a possible culprit. Especially in conjunction with say a hose leak.
. Cheers, Greg
Post #530714 13th Oct 2019 9:48am
Smp68
United Kingdom 2015 Range Rover Vogue SE TDV6 Santorini Black
I had a similar thing happen to me and after replacing the pipes at the back of the engine it wast sorted. When the engine started to regenerate the pipes stopped it and caused a rapid build up.
Post #530721 13th Oct 2019 11:45am
DrRob
Dolph-post a picture of the top of your engine with the engine cover removed and we can see if you have the original weaker hoses that are prone to splitting. Upgrade is to heavy duty versions Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530724 13th Oct 2019 11:59am
Dolphinboy
Fuel was nearly full and drive was over 50 mph and cruising for at least 15 mins.
Will post pics tonight. Thumbs Up
Cam Craig too far away to risk driving there on reduced power (one hour and 30 miles away)
Interestingly there was a lot of debris/light coloured dust on top of the plenum when I removed the engine cover so it looks prob like a hose situation. Will investigate further tomorrow.
Post #530765 13th Oct 2019 5:00pm
DrRob
Read this thread as Greg found a hose issue recently.
Also shows difference between original and upgraded hoses
https://www.fullfatrr.com/forum/topic52807-45.html
Post #530768 13th Oct 2019 5:18pm
GGDR
sounds like you found the culprit dolphin.
. Cheers, Greg
Post #530778 13th Oct 2019 6:45pm
Dolphinboy
Right,IID arrived and this is the fault code.
Cant find out yet how full the DPF is but does this mean I need a new sensor or just get under and check the wiring (anyone care to guide me where it is situated? Have tried but can't get on RAVE for some reason?)
Ps I haven't tried to clear anything yet.
OK just found this. No 9 is the badger!
Is there a sensor in the engine bay? (one mech said there was but it may be for another Marque)
Post #530976 15th Oct 2019 3:08pm
Dolphinboy
FIXED!!
right, got down underneath and checked the sensor codes cleared and no reappearance on start-up.
Live value shows 26.7g of soot so going to see if it will re-gen of its own accord on a motorway drive now.
If not then it's replace the sensor.
Thanks for all your help guys.
Post #530983 15th Oct 2019 3:50pm
DrRob
Non Continuous Soot Mass is the field that shows DPF soot level Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530986 15th Oct 2019 3:56pm
Page 1 of 4 1234>
