Home > Technical (L322) > DPF full. see dealer message out of the blue.Sensor failure? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Donut hoses are common. Search you'll find loads.
12th Oct 2019 8:27pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
As Greg said. Don’t drive it. Get it to a good independent specialist ASAP to read codes and work out what’s wrong with it. It’s usually not the DPF itself but other issues like Greg mentions.
12th Oct 2019 9:30pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3058 |
Thanks guys. I have spent most of today reading all your excellent posts ( ) and have come to the conclusion that it is not being allowed to regen due to a sensor failure. Either EGT, or throttle body or some other?
12th Oct 2019 11:11pm |
I guess it's possible.
13th Oct 2019 8:40am |
Have you got a decent independent specialist around you?
13th Oct 2019 9:06am |
Oh also dolphin, again on the best-to-eliminimate-the-basics logic:
13th Oct 2019 9:48am |
Smp68 Member Since: 04 Oct 2018 Location: Verwood Posts: 20 |
I had a similar thing happen to me and after replacing the pipes at the back of the engine it wast sorted. When the engine started to regenerate the pipes stopped it and caused a rapid build up. |
13th Oct 2019 11:45am |
Dolph-post a picture of the top of your engine with the engine cover removed and we can see if you have the original weaker hoses that are prone to splitting. Upgrade is to heavy duty versions 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Oct 2019 11:59am |
Fuel was nearly full and drive was over 50 mph and cruising for at least 15 mins.
13th Oct 2019 5:00pm |
Read this thread as Greg found a hose issue recently.
13th Oct 2019 5:18pm |
sounds like you found the culprit dolphin.
13th Oct 2019 6:45pm |
Right,IID arrived and this is the fault code.
15th Oct 2019 3:08pm |
right, got down underneath and checked the sensor codes cleared and no reappearance on start-up.
15th Oct 2019 3:50pm |
Non Continuous Soot Mass is the field that shows DPF soot level 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
15th Oct 2019 3:56pm |
