![]() | Home > Maintenance & Mods (L322) > New issue... racket from the front.. fast idle... temp prob |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1395 ![]() ![]() |
Ect needs changing out |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
What’s the ect ?
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 929 ![]() ![]() |
Likely a failed coolant temp. sensor, although can’t help with the location on a 4.2 SC. |
Thanks here is a video just in case someone thinks it’s in my head |
Engine coolant temp sensor, probably reading implausible error and engine goes to failsafe mode, quite easy access and no need for drawing down |
Drawing down? Which one? I have managed to get the bottom one that goes into the oil filter housing as it’s shared with a Ford Focus ironically and ford had one on the shelf the top one not so lucky will have to order however it seems to be working with the bottom one unless it’s intermittent- I will get a top one anyway and stick to short drives for now...
I did put draining down honestly.
Maybe you need to do the bottom one too and I will do the top one for good measure |
Right... fixed the leak put rtv sealant around the threads an tried again..
Hi all
Ok - I have just put two and two together(and wasted money)
Take it back to whoever fitted the lpg system, it's his work that's caused the issue |
Yea that’s the plan but I am taking it to Manchester first thing Monday so was hoping someone may have an idea but if not will have to take when back Current stable:
Ok looks like it may be lpg related
