Home > Maintenance & Mods (L322) > New issue... racket from the front.. fast idle... temp prob
Danwilderspin
Hi all
So once again the 4.2 has treated me...
I have just got a p0116 code with the fan being on full speed all the time sounds like a space ship driving along - idle raising to 1k all the time and temp not getting hot, sat around 20%- are these normal symptoms of a temp sensor if so which one? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531356 18th Oct 2019 8:28pm
dingg1
Ect needs changing out
Post #531370 18th Oct 2019 10:55pm
Danwilderspin
What’s the ect ?
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531377 19th Oct 2019 7:33am
JCW
Likely a failed coolant temp. sensor, although can’t help with the location on a 4.2 SC.
Post #531383 19th Oct 2019 8:03am
Danwilderspin
Thanks here is a video just in case someone thinks it’s in my head Rolling with laughter
There are two sensor - one part is interchangeable with a Ford Focus (the lower one) so hoping I can pop to ecp and they will have in for a test Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531384 19th Oct 2019 8:07am
dingg1
Engine coolant temp sensor, probably reading implausible error and engine goes to failsafe mode, quite easy access and no need for drawing down
Post #531396 19th Oct 2019 9:42am
Danwilderspin
Drawing down? Which one? I have managed to get the bottom one that goes into the oil filter housing as it’s shared with a Ford Focus ironically and ford had one on the shelf the top one not so lucky will have to order however it seems to be working with the bottom one unless it’s intermittent- I will get a top one anyway and stick to short drives for now...
Question re the little one at the bottom - it’s too weird shaped to get the torque wrench on so I have left slightly less threads visible as to the previous one but it’s weeping oil a bit - any ideas?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531444 19th Oct 2019 3:35pm
dingg1
I did put draining down honestly.
Top one I changed but still now and again have the issue with the fan coming on.
Switch off then back on and all is well in the world, same dtc 0116
Post #531459 19th Oct 2019 4:53pm
Danwilderspin
Maybe you need to do the bottom one too and I will do the top one for good measure Smile just need to sort the leak Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531495 19th Oct 2019 9:29pm
Danwilderspin
Right... fixed the leak put rtv sealant around the threads an tried again..
Ok so I went for a drive for about 8 miles and the temp only got to 1/3 but no fan noise, however I put my foot down and got reduced performance mode?
I then drove 2 miles further (a couple of mins later) and it shot up to temperature fine. I carried on driving about 4 miles and it was fine. I then stopped for 5 mins the dial was in the middle but progressively came down to 1/3 again on the 5 miles home?
Scratching my head any ideas? Also as a side my aux coolant pump buzzes when ignition is on but car is off not sure if that’s normal or could form part of this issue...?
Also no faults were logged Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531556 20th Oct 2019 5:52pm
Danwilderspin
Hi all
So lots of updates here...
After I did the lower temp sensor I managed to get the one in the top but a pattern part and EVERY time I started the car from cold and went for a drive it got to temperature and it would drop into cold and the fans would go. I turned it off and on again and it’s fine from then on...
Thought that’s what you get for a cheap part for a genuine lr one fitted yesterday... same thing still, also fitted a supercharger coolant pump
And thermostat and bled it all... really at a loss on this temperature one any ideas? Could it be the lower oil one is no good even though it’s new? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532918 1st Nov 2019 11:37pm
Danwilderspin
Ok - I have just put two and two together(and wasted money)
After I got everything sorted I recently had it lpg converted.
Now my research today shows me that from cold if I just leave on petrol no weird temp fault. As soon as I put on lpg for the first time of the day the temp drops fans come on. Turn it off and on and it’s fine on lpg until the next day... any ideas on this one? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532959 2nd Nov 2019 3:04pm
dingg1
Take it back to whoever fitted the lpg system, it's his work that's caused the issue
Post #532965 2nd Nov 2019 4:06pm
Danwilderspin
Yea that’s the plan but I am taking it to Manchester first thing Monday so was hoping someone may have an idea but if not will have to take when back Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532969 2nd Nov 2019 4:24pm
Danwilderspin
Ok looks like it may be lpg related
Found this post with no remedy but exactly the same :—(
https://www.fullfatrr.com/forum/topic6127.html?highlight=drops
I wonder if anyone knew the person who posted ? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #533264 5th Nov 2019 10:24pm
