![]() | Home > Technical (L322) > park heating |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 190 ![]() ![]() ![]() |
Mine only fires us when it’s cold outside ( remote flash’s green every few secs ) |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 669 ![]() ![]() ![]() |
We have had various FBH faults over the years, here’s some symptoms and fix’s that worked for us:
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Well the time came to finally test mine this morning at 6am and -1 degrees whilst on a night shift and ....nothing!
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
I’ve learnt most times it’s because the battery voltage is too low for the module. Regards
I’m just checking it with IID now
I found the neat way to rule out the webasto itself is to see if it comes on with a cold engine?
This is exactly how I test it, if it comes on with a cold engine (hold you hand against the exhaust).. then the webasto is fine. Next I check the webasto pump, you can do that by firing it up from cold and touching the pipe work, it will get super hot for about 30cm but no further as you don’t have water circulation.
So yours comes on regardless of whether it’s activated then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Yes buddy.
