Home > Technical (L322) > park heating |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 179 |
Mine only fires us when it’s cold outside ( remote flash’s green every few secs ) |
20th Oct 2019 9:59am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
We have had various FBH faults over the years, here’s some symptoms and fix’s that worked for us:
20th Oct 2019 10:18pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
Well the time came to finally test mine this morning at 6am and -1 degrees whilst on a night shift and ....nothing!
9th Nov 2019 1:56pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
I’ve learnt most times it’s because the battery voltage is too low for the module. Regards
9th Nov 2019 1:58pm |
I’m just checking it with IID now
9th Nov 2019 2:08pm |
I found the neat way to rule out the webasto itself is to see if it comes on with a cold engine?
9th Nov 2019 5:18pm |
This is exactly how I test it, if it comes on with a cold engine (hold you hand against the exhaust).. then the webasto is fine. Next I check the webasto pump, you can do that by firing it up from cold and touching the pipe work, it will get super hot for about 30cm but no further as you don’t have water circulation.
9th Nov 2019 5:38pm |
So yours comes on regardless of whether it’s activated then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
9th Nov 2019 5:45pm |
Yes buddy.
9th Nov 2019 5:48pm |
