Home > Technical (L322) > Key batteries in an 07
Danwilderspin
Hi all, can anyone tell me if the 07 style flip key has a standard non rechargeable battery I can change? mine has just decided to stop unlocking so wondering if this needs changing? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531787 22nd Oct 2019 2:12pm
yes,
no
Post #531791 22nd Oct 2019 2:25pm
Danwilderspin
thanks Stan,
so if they aren't rechargeable and are sealed like mine is are you just meant bin the key when its flat? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531792 22nd Oct 2019 2:27pm
TJH1985
I have changed mine in both our sealed keys, VL2330 soldered in place easy exchange Thumbs Up
I resealed mine with some gasket sealant, and they have been swimming since without issue.
Post #531794 22nd Oct 2019 2:32pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Dan,
Look at Stan's answer carefully:-
Horseshoe key he said 'yes' you can change the battery -- it's not rechargeable
Flip key he said 'no', you can't change the battery it is rechargeable
Really difficult to split the key (if original) without breaking it (I've never managed it) but possible to solder a new rechargeable battery and put the board, chip, and blade in a new shell.
If you need some bits PM me
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #531795 22nd Oct 2019 2:38pm
TJH1985
I found putting the case in a soft jawed vice applied enough pressure to pop open the case on ours, prior I had tried all sorts and they simply wouldn't go!
When we purchased the car, one of the keys had been flat a very long time and even after a battery swop didn't function, we had to reprogram using SDD. Not sure if that was the battery going flat, or something else the key was in almost brand new condition.
Post #531799 22nd Oct 2019 3:14pm
Danwilderspin
Thanks guys I have already swapped mine so should pop open nicely just need to get on with it now I know thanks Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531824 22nd Oct 2019 5:37pm
rar110
I misplaced one of my 2008 L322 keys for about a year, now it won’t remotely unlock the doors. But I can use the key blade to unlock the door, which sets off the car alarm. Putting the same key into the ignition kills the alarm and starts the car no problem.
Do I have a flat key battery? Thanks. ______________________________
Post #571459 1st Nov 2020 3:22am
Danwilderspin
Have you tried the key recode procedure if you search the forum you will find it sorry not sure off hand.
It may just need to be used to charge it or the rechargeable cell may be dead. If you have a soldering iron for about £10 you get a new case and cell and it’s good as new Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #571467 1st Nov 2020 9:44am
rar110
Thanks for the reply.
I have done key recoding a new key with the IID tool (key I bought via forum, now gathering dust as couldn’t be coded even by Indy), but something went wrong and decoded all keys (I blame user error).
While IID tool help desk were exceptional at helping me fix the problem, and recoding all old keys, I’m not keen to do it again unless that’s definitely a fix. ______________________________
Post #571803 4th Nov 2020 1:51am
