![]() | Home > Technical (L322) > Key batteries in an 07 |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
yes,
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2299
thanks Stan,
| TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672
I have changed mine in both our sealed keys, VL2330 soldered in place easy exchange |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102
Dan,
I found putting the case in a soft jawed vice applied enough pressure to pop open the case on ours, prior I had tried all sorts and they simply wouldn't go!
Thanks guys I have already swapped mine so should pop open nicely just need to get on with it now I know thanks Current stable:
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
I misplaced one of my 2008 L322 keys for about a year, now it won’t remotely unlock the doors. But I can use the key blade to unlock the door, which sets off the car alarm. Putting the same key into the ignition kills the alarm and starts the car no problem.
Have you tried the key recode procedure if you search the forum you will find it sorry not sure off hand.
Thanks for the reply.
| All times are GMT |
