![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
Totally agree. Don't go looking for an issue with an IID if the car isn't giving you any warnings i.e. amber warning light. And, don't buy a 4.4 tdv8 (with a DPF) if you're just doing low daily mileage and not giving the car a chance to burn off its dirty soot Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
Unnecessary quote removed
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Matt? ![]() Not true but some oddball cars have definitely experienced this. Eg Regen'ing while sitting in traffic. If you continue city driving at 23g the yellow light will come on sharpish at 23.3g (see my chart page 1). All you need to do at that point is hit a bit of road, set the cruise at 50mph and it should sort itself. If you're not getting either warning then carry on camping. Whatever you're doing works. There's no explanation for cars that kinda do their own forced regen but if it keeps high soot output cars happy and soot managed then all good. In this case put away the IID and drive into the sunset. The soot value is a calculated number, not an actual reading and it's based on pressure differential voltage value and a bunch of other parameters. With more experience with mine, I've also learnt that the DPF is more robust than the soot value indicates. Eg a forced regen effectively resets the calculated soot grams to zero and you can keep going. Which I recently did with my new DA-DPF Tool. After reset, soot kept climbing and although it read say 5g that would have been 33g without the reset. But it kept going to 20g so from the red at 28 that would be 48g without a regen. But as I said it's a theoretical number and the ECU is tricked by the reset and the real health of the DPF - the exhaust pressure - was ok, as measured by the pressure differential voltage value. Mine would not regen until I hit 20 (kinda 48g if you add the two) it regen'ed fine and has been fine with a second regen since then back to 1g Ash does build up and is not incinerated as opposed to soot which burns off so I suspect people with ongoing issues and high miles may need off-car cleaning like I had a while back. . . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
I tried last night and when I boot the throttle it does indeed jump: 1.3-1.4 . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Hi all
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3278 ![]() ![]() ![]() |
@m@r]{
And with some fuel in the tank. Needs over a 1/4 iirc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
"DPF remaining volume" is not populated. "Number of Demanded Regens" is a useful field to tell you when Regens are happening. The regen perameters seem to be less stringent as the grams increase and the Regens trigger more readily with greater frequency. On mine if I am on the motorway going quickly a regen will trigger at 17.6grams every time. If I am in traffic it happens at 19.6grams the instant I blip over 37mph. My car happily sits at between 19 and 23 grams forever. If I didn't havre an IIDTool I would never know there was an issue. I drove through central London the other day up to 23 grams, it just sorted itself out at the first opportunity. Also don't expect to get down to 2grams every regen. There is a lot of needless DPF anxiety from misleading interpretations of the IID Tool numbers. The best advice is just don't worry unless you get a warning light. Regens do not happen in a straight line graph, there is a bit of dark arts about it and the info we see is tricky to interpret until you get really deep into it. |
Following my successful resolution of the dpf full/ red warning appearing a while ago, car has been behaved faultlessly with daily 50 mile motorway trips. Dpf was sitting around 20g (following Posts on here not a worry).
Right, a high pressure smoke test has identified a small crack in the Pax side Inlet manifold. This appears to have caused the DPF to fill up and be unable to regen.
Good news you may now have found the root cause of your ongoing soot issues DB.
Suggest getting the manifold done and taking it to somebody else to force-regenerate the DPF. Why not get the DPF removed and cleaned after all this and you know it's good. DPF cleaning companies can clean it and deal wit the with 29g if you or dealer are struggling. Just don't use an on-car service. They are fake. Use somebody with a 'flash' cleaning machine. I would be doing that rather than changing sensors. The set up for new sensors is a big deal. You can find a chunky section in the workshop manual. BTW I did think your oil dilution was not the root cause. It's almost always air/boost leaks. But good to hear you are nearly there. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Hi Greg
Are you using a main dealer or a decent indy? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Ah geez £1600 - wow.
