Home > Maintenance & Mods (L405) > Xenon Upgrades?
Page 1 of 5 12345>
awclymm
Xenon Upgrades?
The Xenons (non adaptive) in my MY2017 SDV8 AB are less than impressive. My last L322 Westminster had far more powerful lights.
Are there any aftermarket bulb upgrades that anybodycould recommend??
Thx 2017 4.4 SDV8 Autobiography
Post #534425 16th Nov 2019 9:17am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I’ve just put Osram night breakers in mine, certainly seems slightly brighter. Issue is there isn’t a separate high beam lamp, that’s why they are less than great vs the 322, until you get to the super fandango matrix ones. CRAIG has fitted a light bar behind the grille, seems to be the least expensive option over a full front end upgrade.
Post #534427 16th Nov 2019 9:33am
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I changed mine for Nightbreakers as well, not cheap and not terribly easy to fit, but a definite improvement Very Happy
Post #534430 16th Nov 2019 10:28am
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
I’ve been looking into lighting options as i live rural down single track roads with kamikaze deer.
Still have my Lazer Grille with ST4’s from my old Defender and i’m considering getting a grille and playing with a 3d printer to mount the ST4’s in it for the winter.
I had seen that Craig had mounted one behind the grille but was concerned you’d lose a lot of the available light being blocked by the grille.
I was also looking at replacing the bulbs as well as Xenon’s aren’t for life and they do deteriorate over the years.
Post #534436 16th Nov 2019 11:18am
awclymm
I'm hearing good things about the Osram CBB bulbs.... 2017 4.4 SDV8 Autobiography
Post #534448 16th Nov 2019 12:49pm
dazza1983
Ive used osram nightbreakers in all my cars over the last 5 or so years.. They are a massive improvement for any xenon bulb for sure in terms of light on the road and visibillity. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #534450 16th Nov 2019 12:58pm
awclymm
What size are the L405 fittings? 2017 4.4 SDV8 Autobiography
Post #534451 16th Nov 2019 1:04pm
osram and philips have bulbs that claim to have extra 30-50% more brightness and many have confirmed this...
you can also buy 6000k temperature bulbs which give a whiter light and the illusion that they seem more brighter but technically they are not ..
one little trick i also do is to adjust the beams very slightly higher so they cover further on the road..
its best not to adjust to much cos oncoming traffic will be flashing you all the time.. ... - .- -.
Post #534452 16th Nov 2019 1:04pm
dazza1983
D3S I believe. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534454 16th Nov 2019 1:25pm
awclymm
I found these bulbs on Amazon - seems to be a good deal:
https://www.amazon.co.uk/XENARC-BREAKER-br...&psc=1
I think I'll give them a go - got to be better than what is currently fitted.....! 2017 4.4 SDV8 Autobiography
Post #534461 16th Nov 2019 3:17pm
roberlar
They're the ones Thumbs Up
Post #534476 16th Nov 2019 5:56pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Thumbs Up Thumbs Up
Post #534480 16th Nov 2019 6:32pm
awclymm
Now I've just got to learn how to fit them!! 2017 4.4 SDV8 Autobiography
Post #534486 16th Nov 2019 7:36pm
not easy...both air boxes have to be dismantled... ... - .- -.
Post #534488 16th Nov 2019 7:46pm
How hard is that Stan ?
I've kind of goy used to the l405 headlights, but they are sitting in my Amazon basket, but I can't decide whether to pull the trigger.......
Post #534489 16th Nov 2019 7:55pm
Page 1 of 5 12345>
