![]() | Home > Maintenance & Mods (L405) > Does anyone want a winch mount for L405? |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Ok so quick update after a couple of months of use. I have used this reasonably extensively and can say with confidence its grossly over engineered |
Oli Member Since: 24 Jan 2020 Location: Sydney Posts: 3 ![]() ![]() ![]() |
Hi,
I am not sure about a Sport. Its entirely possible that the sport and full fat share the same front end architecture. Perhaps someone on the forum can advise? I have never owned a sport so I am not best equipped to answer.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
oli, read this from the RRS forum,
I should point out this is L405 not L322 I'm sure you can likely buy an off the shelf solution for the L322.. but not the L405 |
CMW Member Since: 27 Dec 2019 Location: California Posts: 1 ![]() ![]() ![]() |
Hi Charles, awesome job!! How did you wire the winch? Did you just wire it to the jump terminals under the hood (I'm in the US) or did you run an additional set of heavy gauge wire back to the battery? |
Exactly that yes, directly to the jumpers. The cable used on the jump point is very heavy gauge wire and more than capable of dealing with the current from the winch.
Thanks Charles & Stan,
Shipping and cost are the biggest issue. I priced up shipping to Australia for another forum member and it was over £400 because of the size and weight
We are starting our first manufacturing run of these week commencing 10th of Feb 2020. They will be available and on sale from the following week. Prices as follows:
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Hi, Charles
Quite possibly yes. I will speak with the engineering company and see if they are able to make some speciality drawings that perhaps an engineer in Australia can follow |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
That would be great |
Hello Charles89 & BlackPerth,
