Home > Maintenance & Mods (L405) > Does anyone want a winch mount for L405? |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
Ok so quick update after a couple of months of use. I have used this reasonably extensively and can say with confidence its grossly over engineered its solid, and very tank like.
7th Jan 2020 8:49am |
Oli Member Since: 24 Jan 2020 Location: Sydney Posts: 3 |
Hi,
24th Jan 2020 12:40am |
I am not sure about a Sport. Its entirely possible that the sport and full fat share the same front end architecture. Perhaps someone on the forum can advise? I have never owned a sport so I am not best equipped to answer.
27th Jan 2020 10:01am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
oli, read this from the RRS forum,
27th Jan 2020 11:04am |
I should point out this is L405 not L322 I'm sure you can likely buy an off the shelf solution for the L322.. but not the L405 |
27th Jan 2020 11:40am |
CMW Member Since: 27 Dec 2019 Location: California Posts: 1 |
Hi Charles, awesome job!! How did you wire the winch? Did you just wire it to the jump terminals under the hood (I'm in the US) or did you run an additional set of heavy gauge wire back to the battery? |
29th Jan 2020 9:26am |
Exactly that yes, directly to the jumpers. The cable used on the jump point is very heavy gauge wire and more than capable of dealing with the current from the winch.
29th Jan 2020 10:01am |
Thanks Charles & Stan,
30th Jan 2020 2:20am |
Shipping and cost are the biggest issue. I priced up shipping to Australia for another forum member and it was over £400 because of the size and weight
30th Jan 2020 8:22am |
We are starting our first manufacturing run of these week commencing 10th of Feb 2020. They will be available and on sale from the following week. Prices as follows:
30th Jan 2020 8:36am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1131 |
Hi, Charles
30th Jan 2020 9:46am |
Quite possibly yes. I will speak with the engineering company and see if they are able to make some speciality drawings that perhaps an engineer in Australia can follow |
30th Jan 2020 9:48am |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 112 |
That would be great I'm certain some guys in Australia (like https://www.aptfabrications.com.au) would be interested.
7th Feb 2020 6:49am |
Hello Charles89 & BlackPerth,
21st Feb 2020 5:37am |
