Home > Maintenance & Mods (L322) > Has anyone tried these LED bulbs?
Page 2 of 4 <1234>
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
No, no disasters, but great to see that you have a positive outlook towards life.
The light from them is a nice crisp white, however they do not have the range of my old H7 bulbs so I will probably replace them with night breakers and put the LED’s in the front fogs.
Jim
Post #541139 20th Jan 2020 9:08am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Interesting, was looking to do same as you after sorting out a friends daughter car out after she had a little mishap (ok she ran into something and smashed lights, bumper and front wing cheaper for her if I fix it with second hand parts) the S/H lights had led bulbs with the fan (normal lights on this car have H7 main beam and dip) and light output from the led bulbs was far superior hence my interest, if your front fogs are same as mine doubt they will fit but you can but try. Hope you enjoyed your chinese ( like the smell of some of it, cant stand the taste myself) Thanks for coming back with your report.
Post #541252 21st Jan 2020 1:13am
Mine in my 322 high beam were twice as bright as the halogens they replaced! Try some with the aluminium cooling ropes on Thumbs Up
Post #541257 21st Jan 2020 1:56am
kds2
Thank you Cam-Tech-Craig, I will seek out those, its the high beam I was interested in, replaced the hid bulbs with some 6K ones must have been 4.5k before and they are better, its a nice white light now not yellow ish as before.
Post #541259 21st Jan 2020 2:23am
pjw888
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
L322 Xenon to LED dipped beam
Hi all, not related directly to this post but I'm trying to get confirmation on upgrading dipped beam to LED in my 2011 FFRR. I see things about just main beam upgrades but find the headlights not the best in darkness. I read some posts which state it cannot be done due to voltage changes or to remove the ballast units and associated wiring. I don't want to make any significant changes. I have seen some DS3 Led's and these are quoted as being a complete plug and play fitment.
Can anyone give some solid and accurate advice please? I'd really appreciate this. Thanks
Post #682358 10th Jan 2024 8:00pm
mjdronfield
Plug and play mate…
https://www.fullfatrr.com/forum/topic68556.html
https://www.fullfatrr.com/forum/topic67685.html
I fitted some of these
https://www.ebay.co.uk/itm/195398486970
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #682361 10th Jan 2024 8:36pm
pjw888
Thanks for all your advice, I'll give these a go.
Post #682480 12th Jan 2024 9:11am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I've just fitted the Bevinsee LED's to both dip/main and main beams on my 2011 MY L322. To be honest the dip beam isn't really any different in output to the HID's, but it matches the main beam in colour so it was worthwhile doing. The main beams however, blimey what a difference, well worth it. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #682481 12th Jan 2024 9:41am
DrRob
Re: L322 Xenon to LED dipped beam
As above, fit Bevinsee LEDs to both bulbs per side all in one go. Huge difference overall to light and appearance.
I've also done the full interior, side repeat indicators, reversing ones and the rear number plate. Refreshes the entire car from Censored yellow bulbs to clear white Bow down
4th post down has my links in there amongst all the other "stuff" Rolling with laughter
https://www.fullfatrr.com/forum/topic44115-75.html
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #682497 12th Jan 2024 12:39pm
JayGee
Finaly got the Bevinsee HID replacements in today (left is the LED )and they are a marked improvement over the original HID which the pic doesn't realy do justice to. Did the main beam last year and it was a massive improvement. May do the front fogs just to complete the set. 2012 TDV8 Vogue (L322)
Post #682511 12th Jan 2024 3:18pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Even in the image you can see a little more glare from the LED...........
Post #682668 14th Jan 2024 12:16pm
JayGee
That's just because it's brighter. The beam patern is very clear and well defined. If I get the chance I'll put one of the old bulbs back in and point it at a wall and take a picture of that. 2012 TDV8 Vogue (L322)
Post #682673 14th Jan 2024 12:29pm
SamThomas
It's not the beam itself that causes the problems - it's the glare caused by poor/unsuitable/missmatched optics.
Post #682828 15th Jan 2024 10:07pm
JayGee
In what ways exactly are the optics poor, mismatched and unsuitable ? 2012 TDV8 Vogue (L322)
Post #682830 15th Jan 2024 10:36pm
DrRob
I'd never go back to old skool bulbs now. Never had anyone flash me on dipped. All good Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #682841 16th Jan 2024 9:22am
Page 2 of 4 <1234>
