![]() | Home > LPG > 4.4 Jag and SC owners on LPG |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
The BMW 4.4 are fine to convert no issues with those ones.
Diesel des Member Since: 26 Jun 2019 Location: Northern Ireland Posts: 16 ![]() ![]() ![]() |
Does anyone know where you can get shims to do a valve clearance reset on a 4.2 SC V8? Also I have heard you can use a tool from the 3.0v6 Jag to compress the bucket to allow access to the shim. Is this true? What clearance are people using? I suspect that checking and resetting the clearance periodically would make a massive difference to valve life on Lpg. Doesn't the BMW engine have hydraulic tappers so they self adjust.. |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Yea the bmw engine does - I didn’t realise that the jag ones were that retro and weren’t.
I have no issues on gas, but I intend on keeping it that way. I'm at 140k miles but only 10k on gas. Have lots of experience of other gas cars, but rr are new to me. |
So are you doing tappets now or getting preemtive advise? Do you have a lube system? Current stable:
I would like to check and or adjust the clearances but as I'm not sure what the clearance settings should be, or have access to a tool to depress the bucket to swap out the shim and also have access to a number of different thicknesses of shim im a bit stuck. I suspect this is how theses engines get the reputation of being soft, as once there is any wear on the valve or seat you quickly use up the clearance which is probably already compromised and then you burn seats and valves. Checking and resetting this clearance would stop this issue. The intervals would be determined through experience. I would be grateful to anyone who can assist with:
MonteCarlo Member Since: 03 Feb 2019 Location: Herefordshire Posts: 74 ![]() ![]() |
VSR is an issue for all Jag V8's and to a degree their straight six..
Regarding valves, the M62 has self adjusting tappets. Jag has DAMB "direct acting mechanical buckets" which is a system they have used forever.. My Jag V6 has 130k and runs perfectly smooth with no noise, the valve seat recession on the AJv8 is caused by excessive heat, and shimming the tappets isn't going to change much in that regard. MC |
The engine gets quieter as the valve clearance reduces. I would be ok with some mild valve noise, with a larger than stock clearance. This also helps with the perceived heat issue. It's not heat that causes the issue in the first instance, it's a lack of clearance causing the hot combustion gases to get past the valve and seat before the piston has moved down the bore which allows the gas to cool through expansion. A tight valve seal will impart less heating to the valve as gas passes it on the exhaust stroke only. Also a good seal gives a large surface area for the valve to dump heat into the seat and head when it's closed.
I found this in the manual. Does anyone have access to the shims referenced? |
I was browsing the web tonight and came across water injection kits to lower the temperature of the combustion chamber.
Possibly, but it's more of a power adder on turbo engines,eg water/meth injection. It suppresses detonation very effectively. Not sure it's the ideal fix for not adjusting valve clearance sufficiently often to stop the valves burning. If the valves always have clearance they won't burn. They may erode at a faster than normal rate, but still provide a good service life. Running on Lpg needs more frequent inspections and possibly adjustments, at least more than never, that seems to be how theses engines get neglected. This is why the BMW engine with its hydraulic adjusting tappets is considered bomb proof.
J19HWS Member Since: 15 Jun 2020 Location: TIPTREE ESSEX Posts: 8 ![]() ![]() ![]() |
I have recently changed my engine (not due to LPG problems) it had done 20,000 ish miles on LPG and I couldn’t see any wear related problems with intake or exhaust valves in fact they were spotless |
So, just an update. Details in the thread below.
