Home > LPG > 4.4 Jag and SC owners on LPG
Page 3 of 3 <123
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I’ve been using LPG for over 15 years and had intermittent issues with various cars. I’ve got a SC in the stable now and there’s no way I’m going to convert that for the reasons Lighthouse alludes to despite having a brand new Prins system and the coding software. I did put hardened valves into one of my cars once but it was the head that then went, and not the valves, again as Lighthouse says happened to him.
I think if you’re going to buy a SC, run it for what it is, but if you want to use LPG, get a 4.4M62 BMW unit.
Regards
John
Post #545640 1st Mar 2020 9:27am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
The BMW 4.4 are fine to convert no issues with those ones.
I just added a 5.0 late L322 to my stable and I am leaving it 100% petrol if you work out the cost of 2 heads or hardened valves you have to do one hell of a lot of miles to offset the fuel cost.
As for why I scaped it was at the point that it was a 2006 car, worth 4K ish and I would have had to spend at least it’s own value to fix it, then you still have all the other things that come with a 15 year old motor like older controls and style. So I scraped and have spent the last 11 months looks for a decent late L322 that has all the things I want.
Like I said before I am not anti LPG it’s great I had my own skid was excellent value in terms of fuel cost. It’s just you need the right engine and the post 2006 SC’s in the range are not them. If your talking BMW lumps I’m the range go for it will be awesome.
It was a sad day saying good bye to a range that you had driven over 60000 miles in and had killed.
Like I said I’m not expert just an amateur who likes to play with his stable of cars from classics to modern day motors.
Whatever you decide good luck and if you do convert an SC flash lune turned to highest injection rate and never let it run out and at least 1 in 4 petrol tanks.
Post #545647 1st Mar 2020 11:13am
Diesel des
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Danwilderspin wrote:
Lighthouse - wouldn’t it have been worth getting the buckets done or new seats hardened seats fitted rather than scrap it?
Does anyone know where you can get shims to do a valve clearance reset on a 4.2 SC V8? Also I have heard you can use a tool from the 3.0v6 Jag to compress the bucket to allow access to the shim. Is this true? What clearance are people using?
I suspect that checking and resetting the clearance periodically would make a massive difference to valve life on Lpg. Doesn't the BMW engine have hydraulic tappers so they self adjust..
Post #546247 6th Mar 2020 10:50pm
Danwilderspin
Yea the bmw engine does - I didn’t realise that the jag ones were that retro and weren’t.
Not sure about the rest of your question but a guy called Matt on here is doing a full tear down and rebuild.
What symptoms do you have and mileage and is it on gas? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #546262 7th Mar 2020 9:11am
Diesel des
I have no issues on gas, but I intend on keeping it that way. I'm at 140k miles but only 10k on gas. Have lots of experience of other gas cars, but rr are new to me.
Post #546270 7th Mar 2020 11:00am
Danwilderspin
So are you doing tappets now or getting preemtive advise? Do you have a lube system? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #546275 7th Mar 2020 11:24am
Diesel des
I would like to check and or adjust the clearances but as I'm not sure what the clearance settings should be, or have access to a tool to depress the bucket to swap out the shim and also have access to a number of different thicknesses of shim im a bit stuck. I suspect this is how theses engines get the reputation of being soft, as once there is any wear on the valve or seat you quickly use up the clearance which is probably already compromised and then you burn seats and valves. Checking and resetting this clearance would stop this issue. The intervals would be determined through experience. I would be grateful to anyone who can assist with:
Confirm the factory inlet and exhaust clearance
Have access to a shim kit or just shims they could rent and or sell.
Are the shims used in other engine's?
Confirm the tool required to depress the edges of the bucket. I believe this bolts in place of a cam cap? Or even a drawing that could be used to make our own?
Yes I'm using valve lube. First engine I have ever used it on. I'm really an Audi turbo guy and they love gas. Hard valves, seats and hydraulic tappers. A winning combination.
Post #546278 7th Mar 2020 12:38pm
MonteCarlo
VSR is an issue for all Jag V8's and to a degree their straight six..
A flashlube system comes highly recommended, and works well on the AJv8..
Post #546431 8th Mar 2020 1:30pm
MonteCarlo
Regarding valves, the M62 has self adjusting tappets.
Jag has DAMB "direct acting mechanical buckets" which is a system they have used forever..
My Jag V6 has 130k and runs perfectly smooth with no noise, the valve seat recession on the AJv8 is caused by excessive heat, and shimming the tappets isn't going to change much in that regard.
MC
Post #546432 8th Mar 2020 1:34pm
Diesel des
The engine gets quieter as the valve clearance reduces. I would be ok with some mild valve noise, with a larger than stock clearance. This also helps with the perceived heat issue. It's not heat that causes the issue in the first instance, it's a lack of clearance causing the hot combustion gases to get past the valve and seat before the piston has moved down the bore which allows the gas to cool through expansion. A tight valve seal will impart less heating to the valve as gas passes it on the exhaust stroke only. Also a good seal gives a large surface area for the valve to dump heat into the seat and head when it's closed.
Do you know if shims from other Jag engine work in this application? Also what about tooling? Cheers
Post #546737 10th Mar 2020 9:14pm
Diesel des
I found this in the manual. Does anyone have access to the shims referenced?
Post #548561 28th Mar 2020 4:48pm
Page 3 of 3 <123
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
