Home > Technical (L322) > 4.2 Supercharged V8 Issues
Page 6 of 8 <12345678>
dingg1
It won't run without the inlet manifold and maf installed, computer will say no....
Get it hooked up and give another try.
Good luck
Post #547197 15th Mar 2020 8:30am
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
the MAF is 'installed'
but it will run with out them. when i was stripping it down i started up and run wiht out it to properly here the supercharger..
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #547219 15th Mar 2020 1:30pm
Danwilderspin
Matt - have you half disconnected the gas?
I may be wrong but I am pretty sure unless you redo all the injector wiring if you just disconnect the gas stuff nothing will work, so I imagine carb spray is the fuel it’s running on..?
Iirc on a gas loom the feed for each injector is is cut from the injectors and ran to the gas ecu inputs the gas ecu outputs to the original petrol and gas injector depending on what the gas ecu says. By half disconnecting anything you may have upset this? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #547256 15th Mar 2020 8:30pm
MattHughes86
Hi Dan
yep this is wat im starting to think!!!!!
once the ecu is re-connected i get a 5 second run.... the really annoying thing is that the bloody system was only half connected.. no switch over switch in cab just bare wires.... no tank in the boot just an end to he copper pipe. 90% of all fittings were loose.
but it look like im going to have to semi plumb it back in.... then get the damn thing to some one to code it back out!!!
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #547257 15th Mar 2020 8:37pm
Danwilderspin
Where are you from? Do you know what make the kit is or was? Are you wanting to refit? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #547262 15th Mar 2020 9:15pm
Danwilderspin
http://www.lpgtrade.com/software/king/KING...iagram.pdf
Can’t find a Romano one but 95% sure the King system is the same - the wiring should be the same I think. Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #547264 15th Mar 2020 9:29pm
dingg1
Strange, mine just stalls if the maf is not connected and will not run at all....
Post #547290 16th Mar 2020 8:25am
MattHughes86
Ding what engine have you got?
i will be putting it fully back to gether at lunch probably not tight theough.
Dan thank you very much i will have a butchers on that in a little bit when i should be working (perks of been the boss)
almost there... need the damn thing to run. change a pipe and the thermostat housing then give it a solid run!
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #547294 16th Mar 2020 8:50am
dingg1
4.2 Sc, disconnect the maf and it stalls and will not start again until the maf is reconnected, I'm not at home at the moment but will give it a go once I get back to double check
Post #547303 16th Mar 2020 10:05am
MattHughes86
very odd...
it might be because i have this bloody stupid gas ecu thingy in there???
but i will let you know around lunch time as im going to try with the plenium and airfilter assy all back on before going eletricval route
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #547305 16th Mar 2020 10:20am
Danwilderspin
I’m pretty sure mine with gas setup (although not currently used) does with no maf as I tried it while trouble shooting last year.
Is all your gas wiring and ecu still connected? Just no tank? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #547322 16th Mar 2020 1:06pm
MattHughes86
HELLO ALL!!!!!!
IT RUNS!!!!!!
bloody heap of silver junk!!!!
but im happy now.. had to reconnect the GAS ECU (which had already been done loads)
reconnected everything else
then borrowing the rather expensive reader from the INDY LR guy next door i smashed reset on all engine concered items..
is that the correct way??? i have no idea lol
i do need to sort the water system out now as there is a leak (damaged hose)
and i hope that also sorts teh squeak out (it has been apart almost ten months)
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #547331 16th Mar 2020 2:58pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
well done Thumbs Up Thumbs Up
Post #547353 16th Mar 2020 6:41pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Nice one. That must have been so satisfying to hear it come alive.
Post #547374 16th Mar 2020 8:35pm
Danwilderspin
Nice one - are you going to get a tank for the gas or even if you don’t use it or attempt to unravel the spaghetti for loom Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #547388 16th Mar 2020 9:37pm
