Home > Technical (L322) > TDV8 Alternatorh how to change/replacement pics |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Alternator, belt coolant and header tank all arrived ok but found 2 of the idler pulleys are noisy and have play when tested with no belt, no noise evident before... car only has 80k miles on it so surprised they have failed so early. Going to replace all 3 idlers and the tension.... IR have stepped up to help get them to me ASAP as the car is now off the road.
25th Mar 2020 2:28pm |
Just to be helpful:
25th Mar 2020 2:58pm |
Just received and fitted new pulleys
31st Mar 2020 8:06pm |
First road test showed battery voltages as follows:
1st Apr 2020 1:11pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Just found this very useful thread!
13th Feb 2021 3:45pm |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
Sure sounds like it, What was the battery voltage prior to starting? Your using a multimeter on the terminals?
13th Feb 2021 6:52pm |
Hi Dave, battery was 12.3V. I’m using a Sealey AK500 to check (plugs into cig lighter socket)..... |
13th Feb 2021 8:06pm |
Thunderbird2 Member Since: 06 May 2021 Location: Sydney NSW Posts: 7 |
Hi all
22nd Aug 2022 1:00am |
