Home > Technical (L322) > 4.2 SC lean codes |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 316 |
ill give that a shot if this doesnt pan out. but now its been 3 items, o2 sensors, maf or could of been weak plugs. and my plugs had some serious color to them. for anyone interested
17th Jun 2020 6:59pm |
i did plugs. am waiting on delivery atm, eurocarparts only has delphi and not denso. |
18th Jun 2020 1:18pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Don’t even bother with Delhi-
18th Jun 2020 1:25pm |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 |
This was the leak on my engine that caused it to run lean. Couldn't detect by the usual methods.
19th Jun 2020 8:34am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
Same issue on mine at the pcv
19th Jun 2020 9:04am |
Would a smoke test not show the problem? Also doesnt explain why it only errors on 1 bank on LPG. Am getting GAP tool today, and maf on monday hopefully. So can also install new sensors and clear adaptive values. |
19th Jun 2020 9:09am |
Mine only had the code on LPG and on one bank. It was fine on petrol.
19th Jun 2020 9:52am |
ah so get this. on petrol both banks are lean, only lpg, only bank 1 is lean |
19th Jun 2020 9:55am |
And if it helps, the reason I know my LPG system fuels leaner is because I can watch the fuel trims increase when I change from petrol to LPG as they richen the mixture to achieve the correct fueling. The result is the fueling is OK, as long as the adjustment is within the authority the trims have.
19th Jun 2020 9:56am |
Did it run rough or idle rough or just throw the code? Current stable:
19th Jun 2020 9:59am |
Just threw the code. It did onetime idle a bit rough, but i think thats due to deviation in fuel trims between petrol and lpg. so i cleared the errors, put 20quid of petrol in there and went for a hard drive. issues came back, so waiting on the maf and gap to turn up |
19th Jun 2020 10:00am |
If you get no code on petrol, its probably because the trims can cope with the leak. Why it throws a code on only one bank for the LPG scenario (same as mine) is something I cant get my head around unfortunately! It may be down to the mapping in the LPG ECU having a bias one way or the other, it may not. If you get a code on both, then it may be that any leak is gross enough for the fuel trims not to have enough authority on either fuel. I think the pipe cost me £14 for a couple of metres delivered, so it was a cheaper fix than plugs etc! Rob 05 L322 4.2SC 2016 Discovery 4 Graphite Lotus Carlton Ascona 400 Volvo V70R AWD manual Suzuki 1200 Bandit Velocette Venom BMW R80/7 Daimler V8 250 Mini Cooper S Works 2006 |
19th Jun 2020 10:02am |
ill give it a shot when my other fixes dont pan out its a bit of an annoying issue since it only occurs in certain parts of the rev range but never when idling |
19th Jun 2020 10:30am |
Mine never happened on idle. Once I was driving, initially it only happened when I drove faster, if I drove very steady it was OK. However, once I fitted the expensive (did I mention that !) OE pipe, I think the leak got worse and it happened every time I drove it pretty much. 05 L322 4.2SC
19th Jun 2020 10:34am |
