![]() | Home > Maintenance & Mods (L322) > sidelight LEDs |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
Toning down the side light lumens is easy enough.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
The apparent resistance of LEDs will be much higher rather than lower then filament bulbs. The flashing is likely to be a 'cold filament check' Its a few short pulses of power and the current is measured to see if the bulb is present and working. The pulses are too short to illuminate a filament bulb but LED's are instant and on hence you see the flashes. I had this on my Touareg and I could switch off cold filament check to stop it with the diagnostics kit VCDS just like the IID tool for Range Rovers. BMW i3 Electric Car
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Ah yes the cold filament test, I’ve wondered what that is in IIDControl, so will disable thanks.
Have you seen these threads: https://www.fullfatrr.com/forum/topic21661.html?highlight=led https://www.fullfatrr.com/forum/topic22712.html?highlight=work ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
ah the good old days Ryan |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 214 ![]() ![]() ![]() |
Just fitted these to my Fatty - Philips Light W5W T10, 6000 Kelvin - no can is error, nice and bright - will upload pic of packet if necessary L322 TDV8 4.4 - current
