|  | Home > Maintenance & Mods (L322) > sidelight LEDs |
| RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250      | Toning down the side light lumens is easy enough.
|  29th Jun 2020 6:32pm |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464      | The apparent resistance of LEDs will be much higher rather than lower then filament bulbs. The flashing is likely to be a 'cold filament check' Its a few short pulses of power and the current is measured to see if the bulb is present and working. The pulses are too short to illuminate a filament bulb but LED's are instant and on hence you see the flashes. I had this on my Touareg and I could switch off cold filament check to stop it with the diagnostics kit VCDS just like the IID tool for Range Rovers. BMW i3 Electric Car
|  29th Jun 2020 6:50pm |
| fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124      | Ah yes the cold filament test, I’ve wondered what that is in IIDControl, so will disable thanks.
|  29th Jun 2020 8:58pm |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218      |
 Have you seen these threads: https://www.fullfatrr.com/forum/topic21661.html?highlight=led https://www.fullfatrr.com/forum/topic22712.html?highlight=work   | ||
|  30th Jun 2020 6:33am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | ah the good old days Ryan   | ||
|  30th Jun 2020 7:05am |
|  30th Jun 2020 12:53pm |
| Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 214      | Just fitted these to my Fatty  - Philips Light W5W T10, 6000 Kelvin - no can is error, nice and bright - will upload pic of packet if necessary L322 TDV8 4.4 - current
|  30th Jun 2020 7:25pm |
| Posting Rules
