Home > Technical (L322) > l322 rain sensor/intermiant
dan_uk_1984
johnson1 wrote:
My mate has an 05 Vogue WITH rain sensor but WITHOUT auto lights. Odd I know...
Not odd at all.
Auto lights were 55 plate+
Post #99807 30th Dec 2011 2:56pm
johnson1
I always thought they were part of the same sensor. I can't see any difference between the windscreen sensor on my car to their 05...
Post #99808 30th Dec 2011 2:57pm
dan_uk_1984
02-55 rain sensor only (option on SE/HSE, Standard on Vogue)
55-present rain + Light (Light standard rain optional on SE/HSE)
Post #99809 30th Dec 2011 3:00pm
johnson1
Wasn't disputing your knowledge, Dan Thumbs Up
Just more thought that visually it looked the same and wondered if it was merely software?
Post #99810 30th Dec 2011 3:02pm
A1GSS
That's the same as KLF400... Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #99811 30th Dec 2011 3:11pm
dan_uk_1984
There is an extra sensor in there. Although the housing remained the same.
There is a thread here somewhere about upgrading from rain sensor only to Rain & Auto Lights. One needs the new sensor, new light switch (with A setting) and a new LCM (light control module) which is the most expensive and most difficult to get right part.
Post #99812 30th Dec 2011 3:14pm
klf400
ok took the rain sensor surround off then removed the mirror followed by the rain sensor, disconected the multi plug from the rain sensor and tested the wipers they now work on intermittent so it looks like my rain sensor is shot
the sensor does unclip off but the 2 lenses remain bonded to the windscreen therefore i will try a sensor replacement but if the lens are at fault then i will only replace them if the windscreen needs replacing , i am not that deperate to have auto wipers they work intermittent now so no real issue 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #100074 2nd Jan 2012 12:53pm
I have an 05 plate with auto lights/wipers Very Happy
Maybe the cutover was a bit earlier then??
Post #100077 2nd Jan 2012 12:59pm
tango90
comports wrote:
If it's a 2004 without auto lights then chances are it does not have auto wipers either. Mine didn't until I bought the sensors and new LCM (for the lights)
Easy way to check is to look from the outside at the rear view mirror base. You will see the sensor below it if it has them. There is a thread with pics but can't find it right now.
Edit look here (http://www.fullfatrr.com/forum/topic4836.html) - 9th post down by SteveMFR
Could you tell me what I might need to upgrade my 04 to auto lights and wipers?
Post #574784 1st Dec 2020 6:19pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I did this on my 54 plate a way back
Essentially you need to replace the Light Control Module (LCM) - I went with a used one but you get a dot next to the mileage displaye don the dash to advice of a non matched module
You will also need the updated sensor inside the rear view mirror base on the windscreen - I can't remember if I needed a new screen for the sensor to work correctly but I needed one anyway (£75 insurance xs job)
Just thinking back, you might also need an updated light switch that has the auto setting - but I'm sure someone more knowledgable will be along soon to help out on that one Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #574797 1st Dec 2020 7:45pm
comports
In fact - See here - https://www.fullfatrr.com/forum/topic4836....p;start=30 - page 3 - second from bottom post - I listed out all the parts with part numbers that you need to do this mod.
Smile Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #574798 1st Dec 2020 7:56pm
tango90
Thank you guys.
Post #574802 1st Dec 2020 9:29pm
Gordo51
Canada 2008 Range Rover Supercharged 4.2 SC V8 Barolo Black
The intermittent wipers on my 08 RRSC do not work. Installed new sensor and no luck. Took to dealer and they could not get working. They blamed my non LR replacement windshield. Windshield installation place they recommended laughed at them as LR does not make its own windshields. Living without intermittent wipers.
Post #574916 3rd Dec 2020 6:44am
tango90
Hi Ash,
I forgot to ask are the wipers full auto or does it use the intermittent function?
Post #574922 3rd Dec 2020 10:19am
