![]() | Home > Technical (L322) > l322 rain sensor/intermiant |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
Not odd at all. Auto lights were 55 plate+
02-55 rain sensor only (option on SE/HSE, Standard on Vogue)
| johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519
Wasn't disputing your knowledge, Dan |
| A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973
That's the same as KLF400... Graham
There is an extra sensor in there. Although the housing remained the same. There is a thread here somewhere about upgrading from rain sensor only to Rain & Auto Lights. One needs the new sensor, new light switch (with A setting) and a new LCM (light control module) which is the most expensive and most difficult to get right part.
| klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210
ok took the rain sensor surround off then removed the mirror followed by the rain sensor, disconected the multi plug from the rain sensor and tested the wipers they now work on intermittent so it looks like my rain sensor is shot
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
I have an 05 plate with auto lights/wipers |
| tango90 Member Since: 13 Mar 2019 Location: Ireland Posts: 7 |
Could you tell me what I might need to upgrade my 04 to auto lights and wipers? |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
I did this on my 54 plate a way back
In fact - See here - https://www.fullfatrr.com/forum/topic4836....p;start=30 - page 3 - second from bottom post - I listed out all the parts with part numbers that you need to do this mod.
Thank you guys. |
| Gordo51 Member Since: 16 Jul 2018 Location: Chilliwack Posts: 16
The intermittent wipers on my 08 RRSC do not work. Installed new sensor and no luck. Took to dealer and they could not get working. They blamed my non LR replacement windshield. Windshield installation place they recommended laughed at them as LR does not make its own windshields. Living without intermittent wipers. |
Hi Ash,
