![]() | Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 117 ![]() ![]() ![]() |
If you send me your email I can send you the info.
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
These are the two installation PDF's, current as of September 2020. He'll send you the latest versions once you place the order too. The PDF's look like they skip out a few things (which they kind of do), but once you get going with it it'll become obvious and the additional comments and pics on here will certainly help. https://www.dropbox.com/sh/dbiw3wq2dx7u98l...6KkPa?dl=0 I'm a total noob when it comes to the L322 and I managed it, so anyone can ![]() |
jjfang Member Since: 13 Nov 2020 Location: Chicago Posts: 45 ![]() ![]() ![]() |
Thank you so much! Also when you guy were tearing apart the dash, were there any pop tabs or any clips that snap easily or fly off that you guys would recommend me to buy just to have in case? |
I only managed to break one tbh and I'm a bit ham fisted. It was, from memory, the trim above the glove box where it says "Range Rover".
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Are these kits really £650 plus all the hands on |
More like 720quid with the wireless and steering-wheel-control add ons, yup.
flashheart59 Member Since: 27 Jul 2013 Location: Essex Posts: 26 ![]() ![]() ![]() |
I’m seriously tempted by this setup, looks a very well resolved solution. Could someone advise me please, is the wireless CarPlay necessary/worthwhile over a USB connection? I’m a little confused by the naviplus site where it seems to say you have to switch to aux to make or receive a phone call. I’d really appreciate any feedback. Also, would anyone who’s done the conversion consider installing or helping me install in my 2010 5.0 AB with dual screen obviously for sensible £ amount??? Based Essex/Suffolk. |
I'm not sure I'll ever use the wireless option to be honest. I mostly bought it as at 100 extra quid, it seemed worthwhile to get and do at the same time and would possibly make it more attractive an option when I come to sell the car.
Did you do a hard wire connection for the aux connection and where did you place the external mic then? |
So I believe since the earlier installs in this thread, they must have updated the kit, for me everything was plug and play, the loom is untouched and the AUX connection just bypasses the connection on the head unit - you don't have to do anything with the wiring under the armrest for the AUX connector.
Could anyone maybe assist me? I’m in the process of installing this unit for my single view system. Does anyone have Steve’s WhatsApp so I could ask questions? |
I just have the sales email - but he responded pretty quickly on that!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3882 ![]() ![]() ![]() |
He’s on +61433596623 from the UK.
Thank you everyone! I was able to get it installed in a day, it was about 8-9 hrs of work with two guys. Couple things I’ve noticed, the HDMI is really sensitive if you don’t get it right then you will get “Navi no Signal” in addition the Aux connection/bypass plug is sensitive too, if you don’t get it just right in the module behind the fuse box then you will get audio coming from one side only. I was able to put everything together relatively well!
