![]() | Home > My Range Rover > New RR now picked Up |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
Sounds like it’s best to get it checked then. Mines mostly left in the auto fan and auto distribution setting. Don’t very often select face vents, think mine work 🤣
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
Also, the vent in the centre of the dash has a slider which goes from cold to hot - it will always be cold if it's on the cold setting, regardless of the climate settings.
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Thanks, just seems a little feeble on the heating front, will check that centre vent to see how it's set. Yes on my rear camera it stays on for. A few seconds when selecting D but then goes off.. going in after Christmas to get it all checked out. Will let you know outcome.
lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59 ![]() ![]() ![]() |
Mine seems to do the same, I just keep pressing the brake and button eventually it goes. For those 20 seconds I am watching my wallet get emptied in my head. 2009 TDV8 3.6 |
Been out in mine today. Never really noticed, but rear camera stayed on for a few seconds after selecting D....
Sounds like it's not unique but I guess few things are on these! Hope it's just an occasional occurrence. Maybe the A/c is as good as it gets but will see what garage says. My Jag one has never been touched but is still icy cold and hot when it's requested. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Also clean out the little vent in the heating control panel. Behind it is the temperature sensor and there is a little fan which blows over it.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
It is a climate control system that I've experienced on no other car, I still find it annoying. But for whatever strange British engineering concept it isn't just controlled by the climate control controls, the horizontal rotator below the central vents seems to do the actual job of the settings. Well on mine it does, perhaps your is the same. Generally keeping it in the middle of blue/red seems to work, but if it is more towards the red it goes much warmer, and if it is in the blue zone the aircon seems to kick in. A very odd user interface in my opinion. But at least I now no longer feel like I have to take the system apart and can confirm my aircon and heater exchange work just fine. But in my opinion, whoever thought of those controls should be sacked and shot ![]() |
The control under the central vent controls the vent temperature relative to the main control settings, so you can have the vents a bit warmer or cooler than the rest of the system. Some folk like cooler air to face but warmer feet.
Maybe mine is broken as it affects all air temperature dramatically. |
You mean it affects the temp from *other* vents too?
Seems to be a few things that can affect how it heats/cools. Will check temp sensor and try and give it a blow through. Central vent was sent on cold, have moved it to the red sector and will see tomorrow if it changes anything. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
