Home > Technical (L322) > Reduced Engine Performance...AGAIN!!!
Page 4 of 28 <123 45 ... 262728>
Ashmyster79
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Great. I will give him a call monday. Cheers Current Cars
L405 Range Rover Vogue 4.4 Diesel
Previous cars
Lamborghini Gallardo
2006 Range Rover Vogue 4.2 V8 Supercharged Petrol
1996 Williams Clio 2
Aston Martin V8 Vantage
Bentley GT Continental
Porsche Cayenne 4.5s
4.2 V8 Supercharged Range Rover
Porsche Boxster 3.2s
Ford Kuga
Nissan 350z
BMW 316
Porsche Boxster 2.5s
Golf 2.8 VR6 Highline
Renault Clio 16v
Vauxhall Nova GTE
Post #578108 2nd Jan 2021 2:29pm
Doesn’t neccesarily rule out the coil packs. Swapping them side to side will just move the fault to the other side and it will still occur.
The fault you have is Ignition coil or misfire.
P - Powertrain
0 - generic OBD code as opposed to MfR specific
3 - ignition/misfire
64 - ignition coil L primary/secondary circuit.
The L in the coil code doesn’t refer to Left as the other codes relating to coils have different letters too A - L
If you have a spare coil then I would start by putting that into each cylinder in turn then giving it a go.
If you have a decent multi meter you can test the resistance of the coil packs on the bench. Have a google on how to. Basically you have to test across primary and secondary coils to see what readings you get. There is nothing that can't be fixed with a hammer😜😜
Post #578112 2nd Jan 2021 2:42pm
Ashmyster79
Cheers for the info. I did test the coils I bought and were all registering 1. I didnt do the test on the original coils which makes sense I should have done this.
However if I no longer get the missfire errors or shows errors on 2,4,6,8 then this would be a coil pack as I just swapped banks of packs.
I still had the reduced engine performance error even with them switched over so they could still be the problem. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #578114 2nd Jan 2021 2:53pm
dhallworth
Swapping the coils from Bank 1 to Bank 2 and still getting the error message could be normal if there’s an issue. Has the fault moved at all?
With the generic code reader you’re likely to be wasting your time unfortunately.
Please do let us know how you get on when you’ve spoken to Martin.
Post #578159 2nd Jan 2021 7:17pm
Ashmyster79
I really need to take it for a longer drive. Swapping the banks over hasnt given me the missfire errors but saying that it might not show until the next time I start it up and drive it so will have to gove it a few days when I drive it. I will give MH a call on Monday see if he can squeeze me in for a plug in and investigation. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #578161 2nd Jan 2021 7:40pm
Danwilderspin
Have you changed the supercharger coolant pump for a new one yet I see a few people telling you to but can’t see you have that was my issue and my buddies for £100 do it it will be due failure soon anyway Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #578196 2nd Jan 2021 11:56pm
Ashmyster79
No havent done it yet. It is on the list of things to do. Po364 seems to be o2 sensor. Missfires can be o2 sensor so am now hedging that way. I willtake it into MH in Dartford. Go over everything that I have done
Sparks
Remap (back to standard)
Fuel pump
Injectors
Coils
Exhaust
Anything else I have done
Will then suggest
pumps
O2 sensors
Superchargers
Wiring
Hoses etc
Hopefully this way it will finally get fixed. Willcost me more but thiz way hopefully someone will say its this or that instead of guess work
Sofar guess work from private garages has cost me £1800 + what I paid for it. Starting not to be cost effective.
The pump ison the list though. 😊 Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #578201 3rd Jan 2021 12:08am
Ashmyster79
I will get martin to do itwhen I take it in. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #578202 3rd Jan 2021 12:10am
Danwilderspin
Yes definitely do the pump in the grand scheme of things a new one is dirt cheap - the only other time I’ve seen it is a badly fitted lpg system where they’ve tried an emulator or the fuel return isn’t right... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #578271 3rd Jan 2021 5:39pm
dhallworth
My car was delivered this afternoon. Read the fault codes, misfire on cylinder 1. Coil pack had melted. Replaced the coil, normal service has resumed Smile
Think I’ve been very lucky.
Post #578284 3rd Jan 2021 7:18pm
dingg1
Excellent news, its great when things go well like that.
Post #578287 3rd Jan 2021 7:46pm
Ashmyster79
Some guys have all the luck ha. Means I am doomed!!!
No glad ot panned out good for you buddy. Nice when it is a simple fix like that. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #578311 3rd Jan 2021 10:23pm
Danwilderspin
Just chatting to someone else and thought - do you have lpg?
Still think it’s the pump but I remember when they calibrated the lpg this came up Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #578472 4th Jan 2021 11:13pm
Ashmyster79
Funny you say that as someone orber day was behind my car and said was it lpg. Its petrol I havent seen or know any different and when I bought it lpg wasnt mentioned. Fuel pump been replaced and has been to two different garages and I havent been told any different. It was tunning really rich when bought it and had massive issues to start which ai have slowly gone through amd amemded
Have tried to get it in to Martin Hind in Dartford but he didnt call me back today. Will try again tomorrow
If I reach back out to the seller he is just going to tell me to foook off. The type of guy who is Censored off all the time amd knew he was selling me a Censored bomb. My fault for buying it though. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #578475 4th Jan 2021 11:43pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Any update mate
Post #578591 5th Jan 2021 11:00pm
