![]() | Home > Technical (L322) > Reduced Engine Performance...AGAIN!!! |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Doesn’t neccesarily rule out the coil packs. Swapping them side to side will just move the fault to the other side and it will still occur.
| Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 247
Cheers for the info. I did test the coils I bought and were all registering 1. I didnt do the test on the original coils which makes sense I should have done this.
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3348
Swapping the coils from Bank 1 to Bank 2 and still getting the error message could be normal if there’s an issue. Has the fault moved at all?
I really need to take it for a longer drive. Swapping the banks over hasnt given me the missfire errors but saying that it might not show until the next time I start it up and drive it so will have to gove it a few days when I drive it. I will give MH a call on Monday see if he can squeeze me in for a plug in and investigation. Current Cars
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2299
Have you changed the supercharger coolant pump for a new one yet I see a few people telling you to but can’t see you have that was my issue and my buddies for £100 do it it will be due failure soon anyway Current stable:
No havent done it yet. It is on the list of things to do. Po364 seems to be o2 sensor. Missfires can be o2 sensor so am now hedging that way. I willtake it into MH in Dartford. Go over everything that I have done
I will get martin to do itwhen I take it in. Current Cars
Yes definitely do the pump in the grand scheme of things a new one is dirt cheap - the only other time I’ve seen it is a badly fitted lpg system where they’ve tried an emulator or the fuel return isn’t right... Current stable:
My car was delivered this afternoon. Read the fault codes, misfire on cylinder 1. Coil pack had melted. Replaced the coil, normal service has resumed |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1420
Excellent news, its great when things go well like that. |
Some guys have all the luck ha. Means I am doomed!!!
Just chatting to someone else and thought - do you have lpg?
Funny you say that as someone orber day was behind my car and said was it lpg. Its petrol I havent seen or know any different and when I bought it lpg wasnt mentioned. Fuel pump been replaced and has been to two different garages and I havent been told any different. It was tunning really rich when bought it and had massive issues to start which ai have slowly gone through amd amemded
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
Any update mate |
| All times are GMT |
