Home > Technical (L322) > TDV8 4.4 engine rebuild, preventative mod info ?
Page 2 of 5 <12345>
mjdronfield
Most issues covered in replies above.
Change the little intake hoses on the donut for silicone ones. They do tend to split. Don’t think anyone makes a silicone set, but someone recently just bought silicone tube and cut to length.....
Though it might be an idea to upgrade all the hoses.
Change the valve on the air con compressor. It’s a bit of a known issue with delayed air con etc. It’s hard to get to otherwise.
https://www.fullfatrr.com/forum/topic43778...ed+air+con
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #584312 18th Feb 2021 4:12pm
Baltic Blue
You haven’t said what mileage it has done, but I suppose most issues will be age related plus normal wear and tear.
Post #584314 18th Feb 2021 4:21pm
Autobiographyblack
101k miles
Post #584315 18th Feb 2021 4:24pm
dhallworth
Wow. That's a fairly low mileage for it to have failed catastrophically.
Are engine components available for these engines? I believe LR tend to supply engines rather than components.
One thing that would be worth inspecting/replacing whilst it's out due to ease of access is the EGR temperature sensor in the NS manifold. Awkward as hell whilst the engine is in but a doddle whilst it's out I believe.
Have you removed any of the glow plugs or injectors to put a camera down any of the bores?
The 4.4 is a great engine and is usually pretty reliable so I hope it's an easy fix.
Post #584324 18th Feb 2021 5:00pm
Autobiographyblack
Havent done anything to it yet apart from try a jump pack, engine will be removed by a friend at his garage, stripped, cleaned and inspected/measured etc, they do lots of RR although he has said this will be the first 4.4 he’s seen with a major problem, i spoke to him before buying it and he is confident that providing the block is not beyond repair he can rebuild it, although LR dont supply internal parts there appears to be plenty of bits about second hand, aftermarket bearings, rings etc are about and LR sell gaskets so hopefully the original engine can be saved but we wont know till its out and stripped.
Post #584325 18th Feb 2021 5:07pm
Baltic Blue
Please don’t mock this idea, but are you sure it is not just the common starter motor problem where you just get a click from the solenoid and it makes no attempt to turn over.
Fingers crossed, it could be a very easy fix.
Post #584326 18th Feb 2021 5:17pm
dhallworth
I was just about the suggest the same as Mike.
Our 2012 4.4 TDV8 is on 22.5k miles but is on it's 3rd starter motor. All they do is *click* when you press the button. It takes 30 mins to get the starter off the 4.4 and it'll come out through the gaps in the subframe so it's incredibly easy to check on the bench with a 12v battery before tearing the whole engine out.
Fingers crossed it could be something very cheap and very simple!
Post #584327 18th Feb 2021 5:19pm
Autobiographyblack
Mike.
Ive already thought of that and it will be checked before pulling engine but i cant see me being that lucky, wouldn't it be nice !
Post #584328 18th Feb 2021 5:21pm
dhallworth
What symptoms are you getting? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #584329 18th Feb 2021 5:23pm
Autobiographyblack
Only symptom so far is not turning over, ive bought the car from a finance company so could only really try a jump pack and have a very brief and basic look over, the starter just clicks but its a bit of a deeper/heavier click than i would expect to hear from just a faulty starter motor, more a stuck crank kind of click/thud, the only background i got on the car is that it was handed back to the finance company due to an engine fault. Ive bought it with an engine rebuild/replacement in mind as worse case so anything less will be a bonus.
Post #584332 18th Feb 2021 5:32pm
dhallworth
Definitely. I might have a video of the clunk from the failed starter on my phone. If I can find it, I'll upload it for you to compare. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #584334 18th Feb 2021 5:35pm
dhallworth
You'll need your volume turned up. It's much more pronounced from outside and is more of a clunk then a click.
When applying 12v to the bendix, it will still engage. Applying 12v to the motor will get the motor to turn.
Applying 12v as the car would will only engage the bendix. The internal link between the 2 on the motor burns out as far as I am aware.
Post #584337 18th Feb 2021 5:42pm
Autobiographyblack
Your getting my hopes up ! It did sound similar to be fair, il have to wait till its delivered to the garage and they will check.
Thanks
Post #584339 18th Feb 2021 5:45pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Does it really? I was quoted 4 hours labour...
Post #584340 18th Feb 2021 5:52pm
Baltic Blue
I have stripped a couple to see what goes wrong and it’s only the contacts that burn .
Have a search , both Mike from Scotland and I have posted threads with pictures showing the fix.
Mike.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #584341 18th Feb 2021 5:53pm
Page 2 of 5 <12345>
