![]() | Home > Technical (L322) > TDV8 4.4 engine rebuild, preventative mod info ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7961 ![]() ![]() ![]() |
Most issues covered in replies above.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3848 ![]() ![]() ![]() |
You haven’t said what mileage it has done, but I suppose most issues will be age related plus normal wear and tear.
Autobiographyblack Member Since: 01 Feb 2021 Location: Shropshire Posts: 33 ![]() ![]() |
101k miles |
Havent done anything to it yet apart from try a jump pack, engine will be removed by a friend at his garage, stripped, cleaned and inspected/measured etc, they do lots of RR although he has said this will be the first 4.4 he’s seen with a major problem, i spoke to him before buying it and he is confident that providing the block is not beyond repair he can rebuild it, although LR dont supply internal parts there appears to be plenty of bits about second hand, aftermarket bearings, rings etc are about and LR sell gaskets so hopefully the original engine can be saved but we wont know till its out and stripped. |
Please don’t mock this idea, but are you sure it is not just the common starter motor problem where you just get a click from the solenoid and it makes no attempt to turn over.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3309 ![]() ![]() ![]() |
I was just about the suggest the same as Mike.
Ive already thought of that and it will be checked before pulling engine but i cant see me being that lucky, wouldn't it be nice ! |
What symptoms are you getting? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Only symptom so far is not turning over, ive bought the car from a finance company so could only really try a jump pack and have a very brief and basic look over, the starter just clicks but its a bit of a deeper/heavier click than i would expect to hear from just a faulty starter motor, more a stuck crank kind of click/thud, the only background i got on the car is that it was handed back to the finance company due to an engine fault. Ive bought it with an engine rebuild/replacement in mind as worse case so anything less will be a bonus. |
Definitely. I might have a video of the clunk from the failed starter on my phone. If I can find it, I'll upload it for you to compare. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Your getting my hopes up ! It did sound similar to be fair, il have to wait till its delivered to the garage and they will check.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2620 ![]() ![]() |
Does it really? I was quoted 4 hours labour... |
I have stripped a couple to see what goes wrong and it’s only the contacts that burn .
