![]() | Home > Technical (L322) > TDV8 4.4 engine rebuild, preventative mod info ? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4337 ![]() ![]() ![]() |
Fit a Denso starter motor. Lot cheaper than Genuine and it’s what a few of us have fitted |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3233 ![]() ![]() ![]() |
It's a Denso we fitted to ours too.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
I forgot to ask that important question just assumed you knew what the fault was!!
Autobiographyblack Member Since: 01 Feb 2021 Location: Shropshire Posts: 33 ![]() ![]() |
Update, its a runner, new battery, bit of fiddling about, erase all codes and it fired into life, seemed it had just been stood and low battery had caused issues, possibly even to the starter as even that needed a tap to get going, after running up to temp and going for a run it seems a good old thing, few oil leaks etc so decided i will continue with the initial plan to pull the engine and replace a fee things to future proof it a bit, list so far is:
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7923 ![]() ![]() ![]() |
That’s cracking news.
Yes its a result, i dont mind going to town on it now as the engine being good gives me more budget |
That is great news |
Ive had a good deal on the turbos so ive gone for it for peace of mind, plus i should pull some money back on the old ones.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2674 ![]() ![]() |
I can't spot any difference to the one in the TSB, other than the label on yours. |
Thats what i thought, just surprised to see prototype on it, im happy to find that its already on it and appears to have been there a long time, also found out today it has very recently had a new cooling fan. |
I see you're in Shropshire....can I ask who is working on it for you? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
My friend works at a garage at a garage in balsall common/coventry, thats where its being done, they do lots of JLR engine work, the place is called Lavender Hall Autos. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
I tell you what mister AB-Black it's a bold move to take out an engine when you don't really need to; just for good measure. This is no MGB. But it's obviously a keeper. I reckon if I had a ramp I'd do the same.
