Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
The 4.4 TDV8 doesn't need a backbox as the DPF kills the engine sound... Try it, remove the whole exhaust from just behind the DPF, you may well be surprised sir... |
24th Apr 2021 1:21am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 368 |
I know this is getting slightly off Sam's original topic, but are we saying that: * Up until 2010, FFRR's with Xenon's had motors in the headlights to do the levelling (as per my quote from the workshop manual and as per my own experience with my 2002 FF which defininately has levelling motors in the headlights) * After 2010, unless the cars have adaptive headlights that swivel around corners (as per my 2011 car as it happens), the headlight levelling is taken care of ONLY by the air suspension? Confused, and wanting to learn more Jon 1992 RR Classic 3.9 efi Vogue =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
27th Apr 2021 6:33pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
Correct Jon, although I suspect that the change occurred with the MY07 when Terrain Response and the D3/L320 RRS air suspension system was introduced rather than at MY10. |
27th Apr 2021 9:43pm |
Thanks GraemeS 1992 RR Classic 3.9 efi Vogue
28th Apr 2021 5:11pm |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
Any update on the height sensor fix? I’ve found that after off-road if the ride quality improves drastically for a few miles then goes back to harsh 1995 4.6 v8, green/tan (long gone)
30th Apr 2021 5:15am |
Reidsr Member Since: 31 Dec 2021 Location: Aberdeen Posts: 10 |
I have the exact same issue. Did you get to the bottom of this problem?? |
31st Dec 2021 6:11pm |
So did I - my fix was new oem front struts/dampers 1995 4.6 v8, green/tan (long gone)
31st Dec 2021 6:27pm |
Hi thanks for the reply.
31st Dec 2021 7:28pm |
Rears made no difference, front fixed it. Is yours an L405? L405 Front dampers failing has come up here a few times 1995 4.6 v8, green/tan (long gone)
31st Dec 2021 9:28pm |
Yeah its a l405. Did yours bounce a lot on the slightest imperfections on the road? And did yours have cdv? |
31st Dec 2021 11:42pm |
Yep I could see the leading edge of the bonnet bouncing. I didn’t notice the movement at first and need a good eye to know what to look for. Yes it had cvd.
1st Jan 2022 12:26am |
Early L405 front dampers were prone to leaking oil into the air-spring, with failing to lower to access height due to the oil being one of the symptoms. Oil doesn't compress so isn't a good substitute for air in an air-spring. The lack of oil in the dampers causes them to be ineffective. |
1st Jan 2022 6:43am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2024 |
when I got mine, I had an adaptive dynamics issue, car sank at front over a few days.. , but looking at the height sensors, one front one, was bent up, and wedged by the rubber elbow of the rod...found whilst first diagnosing the fault with IID. so could BOTH your fronts be wrongly fitted/positioned, and trying to adapt/increase etc? I flicked the sensor lever over, and it slowly settled, and error cleared. |
1st Jan 2022 9:57pm |
Inspected car ride heights today and the o/s/f is sitting higher than the n/s/f. The rears are both the same height.
2nd Jan 2022 5:02pm |
