![]() | Home > Technical (L405) > L405 - Restricted Performance - EGR Valve |
| madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 91
Hi Hawkeye,
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
where are the pics? 2012 Vogue 4.4 TDV8 - Current
| hawkeye651 Member Since: 21 Oct 2019 Location: Melksham Posts: 23
Pics are in the gallery - sorry ..... should probably have inserted them directly into the post!
I'll see if I can get them for you! |
Fault Codes:
| JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203
As you have replaced your EGR you should now have cleaner running, judging by the state of that MAF sensor I would be worried about the soot in the intake manifold (has that been cleaned out)? It's worth checking the state of the MAP sensor also if the EGR valve was knackered, it could that the MAP vacuum is line is blocked having sucked up debris from the manifold. I would check that if they have not done so already. 2021 L405 Vogue D300
Thanks James - much appreciated & I'll pass it on. |
see this post
Many thanks James. |
| jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 |
I think you can't avoid EGR clog up on a diesel car. Hence the ban on them. Carbon and NOS is diesel by product and there is no way to get around it.
Thanks - I don't think my issue is this as it does not throw up these codes??? 2019 Autobiography SDV8 Byron blue/black - current 2016 Vogue SE SDV8 Santorini Black/Ivory - sold 2009 RR Sport TDV8 HSE - sold |
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3284
As you are in Melksham, book it on with Steve at T & s Norman just south of Shepton Mallet. https://www.tandsnorman.com
Love it - many thanks! |
| PC76 Member Since: 28 Oct 2019 Location: Home Posts: 10
Hi Hawkeye,
