Home > Technical (L405) > L405 - Restricted Performance - EGR Valve
hawkeye651
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Having a few issue with my MY16 4.4V8 - might be useful or interesting for someone. Thumbs Up
Restricted Performance issues started a few months back. Indy diagnosed MAP/MAF correlation fault and replaced inlet manifold pipe as this was leaking at inlet elbow. Visually inspected turbo actuator and diverter valve operation found to be okay. Turbo actuator linkage also checked and found to be okay. Removed that sensor and found to be completely blocked map sensor and intake. Removed, cleaned and road tested – fault cleared.
Approximately one month later fault recurred when underload going up hill ... not much fun going up Solstice Hill on the A303 at 25mph!! Censored
Car back with Indy who are now changing the EGR valve which was found to be virtually inoperative due to the crud - see pics.
Hope this resolves the issue - question how to prevent it happening in the future?! This car has had regular longish runs.
Post #596836 8th Jun 2021 5:21pm
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
Hi Hawkeye,
I am having all sorts of similar issues with my MY2016 4.4. Do you know what fault codes were thrown up when this happened? 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #597048 10th Jun 2021 12:25pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
where are the pics? 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #597049 10th Jun 2021 12:30pm
hawkeye651
Pics are in the gallery - sorry ..... should probably have inserted them directly into the post!
Post #597050 10th Jun 2021 12:57pm
hawkeye651
madasmad wrote:
Hi Hawkeye,
I'll see if I can get them for you!
Post #597051 10th Jun 2021 12:58pm
hawkeye651
Fault Codes:
P006A-84 - Absolute Manifold Pressure
P2BAE-00 - NOX Exceedance
EGR Replaced and the NOX has now cleared but the first one remains and garage are fault diagnosis tottery and isolate in. order to resolve.
Needless to say the Warranty Company - RAC Platinum Plus - are attempting to deny any responsibility.
Broadland Landrovers, Westbury, Wiltshire have been excellent throughout.
Any / all ideas / thoughts welcome! Very Happy
Post #597054 10th Jun 2021 1:18pm
JamesD
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
As you have replaced your EGR you should now have cleaner running, judging by the state of that MAF sensor I would be worried about the soot in the intake manifold (has that been cleaned out)? It's worth checking the state of the MAP sensor also if the EGR valve was knackered, it could that the MAP vacuum is line is blocked having sucked up debris from the manifold. I would check that if they have not done so already. 2021 L405 Vogue D300
2016 L405 Vogue 3.0TDV6 (Sold)
Post #597057 10th Jun 2021 2:39pm
hawkeye651
Thanks James - much appreciated & I'll pass it on.
Post #597067 10th Jun 2021 4:58pm
JamesD
see this post
https://www.fullfatrr.com/forum/post442883.html 2021 L405 Vogue D300
Post #597077 10th Jun 2021 6:25pm
hawkeye651
Many thanks James.
Post #597091 10th Jun 2021 8:10pm
jackcramerr
I think you can't avoid EGR clog up on a diesel car. Hence the ban on them. Carbon and NOS is diesel by product and there is no way to get around it.
I am surprised not many people have reported this and swear by their diesel cars to be faultless even though this is an inheret issue.
Post #597140 11th Jun 2021 10:27am
madasmad
hawkeye651 wrote:
Fault Codes:
Thanks - I don't think my issue is this as it does not throw up these codes??? 2019 Autobiography SDV8 Byron blue/black - current
Post #597436 14th Jun 2021 10:18am
Dolphinboy
As you are in Melksham, book it on with Steve at T & s Norman just south of Shepton Mallet. https://www.tandsnorman.com
Wot he don't know about LRs ain't wurf a jot (as we say in theze 'ere partz). He will also analyse and theory test to find a solution.
He fixed my DPF regen fault which no other LR dealer or Indie could (it was a cracked thermostat housing which reduced Engine temps).
Post #597442 14th Jun 2021 10:40am
hawkeye651
Love it - many thanks!
Post #597459 14th Jun 2021 12:35pm
PC76
Hi Hawkeye,
Sorry for resurrecting the old thread but interested if you ever got to the bottom of this?
Thanks
Post #682651 13th Jan 2024 11:47pm
