Home > Technical (L405) > front knuckle cracking
Page 5 of 57 <123 456 ... 555657>
Looking at the failures on these, these they seem pretty instantaneous, there is no discolouration on the edges of the cracks which can be seen. Would you find a crack on one which was about to go bang. Dunno, it’s not a bad idea in principle but not sure you would see anything. There is nothing that can't be fixed with a hammer😜😜
Post #596660 6th Jun 2021 9:24pm
I'm with NMJ, IMHO cast aluminium will not crack like steel, cracks in steel tend to start one side and slowly work across as the material is malleable, aluminium is too brittle, it will fail in one go which is what looks like is happening, it appears corrosion due to dissimilar metals is building up in the joint and splitting it apart.
If I had one I would take the joint apart, clean it well and use some anti corrosion assembly paste (not copperslip) and keep an eye on it in the future... Thumbs Up
Just my 2p... Pete
-Click here for Thread-
Post #596670 6th Jun 2021 10:45pm
Rob99
Brid91 wrote:
a Russian video has emerged showing the fault and the recall notice for vehicles with certain VIN range
Can you post details or a link? A VIN number range would be very useful for owners to check and give them some peace of mind. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #596689 7th Jun 2021 10:33am
Mikey
Not just JLR suffering. This was a 2013 Audi...
Post #597202 11th Jun 2021 8:58pm
Mikey
Out of interest, have any of these cars that have suffered failures, had any suspension work done recently? Question
Post #597203 11th Jun 2021 9:01pm
Kot
Just seen this on the RRS forum
https://www.rrsport.co.uk/forum/topic58333.html 2018 SE SDV8 4.4 Byron Blue
Post #597509 14th Jun 2021 6:45pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Thats not looking good......... BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #597536 14th Jun 2021 9:15pm
swissomatic
United States 2015 Range Rover 5.0 SC V8 Fuji White
Looks like the Sport Forum picture is of another L405 not a Sport..
Post #597550 15th Jun 2021 12:05am
knwatkins
Another one...
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #598429 22nd Jun 2021 11:50pm
ur20v
A Trap
Deleted.
Post #598436 23rd Jun 2021 7:22am
AJGalaxy2012
It hasn't been a 'known' issue until recently and I don't think its across all makes. It's definitely a major cause for concern and should IMHO be subject to a recall by the manufacturers of affected vehicles. BMW i3 Electric Car
Post #598438 23rd Jun 2021 8:17am
ur20v
A Trap
Deleted
Post #598442 23rd Jun 2021 10:09am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Things like that happen all the time. If the mechanics do work on the car and don't torque the bolts properly then it's going to eventually give up due to wither over tightening creating a pressure point or if its not done up enough corrosion will start setting in to the area I guess
Post #598443 23rd Jun 2021 10:30am
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Morning everone and i feel lucky to be alive today as this same Catastrophic failure happened on the nearside of my 2015 L405 yesterday when i was manovering at low speed on a petrol garage forcout after i have just been traveling on the motoway with a trailer, i had the car recovered to my local Landrover specialist who i used for my last service and up utill then it had always be serviced at Lanrover colchester.Its got 84000 on the clock and everything is original on the suspension and its never had damage and never been offroad and ner been kerbed as the original 22 wheels are excellent.
I have found a new part with part number LR134929 which Supersedes LR099134 & LR115105 but the part number it seems i need is LR146343 and i am being told that the wheel knuckle for cars after 2017 might not fit as part numbers changed would anyone know if the part changed or is it just the part number. Or even if there is only one Knuckle that has ever been made for all models of L405 and there have just been part number changes.
Many thanks For any help.
Post #606020 9th Sep 2021 11:30am
Fifth Horseman
Assuming your VIN ends in something earlier than FA207673 then the correct part is LR146343 (the succession of part numbers for these vehicles is LR040119->LR078150->LR078376->LR099019->LR146343 source: JLR online EPC)
List price is £822.60 inc vat (ouch) but it does include the hub and wheel bearing. This fits up to and including 2017 model year.
From the part numbers it does seem that the part changed after 2017 although I am able to find no details as to what changed.
Also as we have seen several of these failures now, please report it to DVSA using this link
Post #606027 9th Sep 2021 2:29pm
