Home > Technical (L405) > Clicking noise when turning left
Bluestu33
United Kingdom 2014 Range Rover Vogue SE SDV8 Loire Blue
Evening all!
I've got a 2014 l405 and I have noticed on the last few drives that when I have the window down and I am turning the wheel towards the left, I hear a clicking noise, which stops when I straighten up.
It almost sounds like there is a stone in the tread, but I have checked that, and there isn't.
Any ideas what it could be and if so, is it covered under warranty?
Thanks in advance,
Post #479490 27th May 2018 8:35pm
CV joint?
Post #479495 27th May 2018 10:33pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Resurrecting this. I’m having this sound from passanger side rear when turning left. Sounds like a pebble is rattling around inside my wheel/tire. I’m guessing bad CV joint? How hard is this to repair on these rigs? DIY? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #598887 26th Jun 2021 9:24pm
knwatkins
I also have this, when turning right. I noticed it a few weeks ago and thought it must be a stone in the tread and noticed it again yesterday. I haven't actually checked the tread of the tyre for a stone though. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #598891 26th Jun 2021 9:53pm
horse86
It definitely has to be suspension related. Bc it Only happens when turning left. I tested in a parking lot going in circles at slow speed and it would start from medium through full tight to the left. I need a buddy to see if it’s the front or rear. Nothing when I turn right.
It’s a metal on metal ticking/slapping type sound 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #598941 27th Jun 2021 9:04pm
Drivetrain, not suspension.
Standard fault on all makes of vehicles with driveshafts that have CV joints.
As the joint wears it makes a noise when turning, leave it long enough and it will tick in a straight line...
It could be a DIY job depending on how rusted together the hubs are..... Thumbs Up Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #598954 27th Jun 2021 10:35pm
horse86
Oh wonderful. Never messed with the drivetrain on this vehicle. So would it make sense it’s only when turning one direction?
I had a leak on the rear diff and had the seal/gasket (pinion?)repaired not more than a year ago. (The common repair/issue on these). Would that be a cause of this or non related?
How bad is it to continue to drive with it this way? Not sure how soon I can get in in for appointment. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #599008 28th Jun 2021 4:06pm
i had this noise with my L322, turned out to be the lower suspension arms... ... - .- -.
Post #599011 28th Jun 2021 4:21pm
Was that a tick, tick tick noise Stan or just one tick when you turned...?
Suspension wear tends to tick as the bush hits the arm so usually just once, CV joints tend to make a repeat noise...
But then it's a fatty so anything is possible...!! Pete
Post #599027 28th Jun 2021 7:58pm
it was a repeat click Pete..i drove on full right lock and my son walked beside the front off side wheel and diagnosed the lower arm bush.. ... - .- -.
Post #599039 28th Jun 2021 9:32pm
horse86
Mine is a repeated tink/click for as long as I’m turning left. Once I straighten out or turn right it stops.
Stan was yours the same symptom? Only turning in the one direction? Was it just the front or rear that was the culprit or did you replace both at the same on the side that was having the issue?
How do I rule out one vs the other. LCA vs CV joint/drive shaft? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #599040 28th Jun 2021 9:40pm
same as you..clicking went when the steering wheel was straight...
i put mine in full lock turned to the right and it was the osf that was the problem...i had both fronts replaced.. ... - .- -.
Post #599043 28th Jun 2021 9:44pm
horse86
Hmm ok. I’ll need to have another set of ears listen for me to determine location 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #599044 28th Jun 2021 9:45pm
Should be easy to check the arm for play to confirm... Thumbs Up Pete
Post #599056 28th Jun 2021 11:31pm
horse86
I suppose once jacked up and pulling on the lower control arm....if it has any play at all it would need rpelaced?
I also have sway bar bushings that I purchased that I need to drop in. Hopefully be able to do that myself as it doesn't look too bad. LCA I doubt bc I don't have the LR separator tool 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #599117 29th Jun 2021 1:46pm
