|  | Home > Technical (L405) > Clicking noise when turning left |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | CV joint? | ||
|  27th May 2018 9:33pm |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | Resurrecting this. I’m having this sound from passanger side rear when turning left. Sounds like a pebble is rattling around inside my wheel/tire. I’m guessing bad CV joint? How hard is this to repair on these rigs?  DIY? 2014 FF Autobiography 5.0 SC
|  26th Jun 2021 8:24pm |
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782      | I also have this, when turning right. I noticed it a few weeks ago and thought it must be a stone in the tread and noticed it again yesterday. I haven't actually checked the tread of the tyre for a stone though. Kev
|  26th Jun 2021 8:53pm |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | It definitely has to be suspension related. Bc it Only happens when turning left. I tested in a parking lot going in circles at slow speed and it would start from medium through full tight to the left. I need a buddy to see if it’s the front or rear.  Nothing when I turn right.
|  27th Jun 2021 8:04pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Drivetrain, not suspension.
|  27th Jun 2021 9:35pm |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | ^^^
|  28th Jun 2021 3:06pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | i had this noise with my L322, turned out to be the lower suspension arms... ... - .- -.
|  28th Jun 2021 3:21pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Was that a tick, tick tick noise Stan or just one tick when you turned...?
|  28th Jun 2021 6:58pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | it was a repeat click Pete..i drove on full right lock and my son walked beside the front off side wheel and diagnosed the lower arm bush.. ... - .- -.
|  28th Jun 2021 8:32pm |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | Mine is a repeated tink/click for as long as I’m turning left. Once I straighten out or turn right it stops.
|  28th Jun 2021 8:40pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | same as you..clicking went when the steering wheel was straight...
|  28th Jun 2021 8:44pm |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | Hmm ok. I’ll need to have another set of ears listen for me to determine location 2014 FF Autobiography 5.0 SC
|  28th Jun 2021 8:45pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Should be easy to check the arm for play to confirm...  | ||
|  28th Jun 2021 10:31pm |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | I suppose once jacked up and pulling on the lower control arm....if it has any play at all it would need rpelaced?
|  29th Jun 2021 12:46pm |
| Posting Rules
