![]() | Home > Technical (L405) > Clicking noise when turning left |
CV joint? |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863
Resurrecting this. I’m having this sound from passanger side rear when turning left. Sounds like a pebble is rattling around inside my wheel/tire. I’m guessing bad CV joint? How hard is this to repair on these rigs? DIY? 2014 FF Autobiography 5.0 SC
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
I also have this, when turning right. I noticed it a few weeks ago and thought it must be a stone in the tread and noticed it again yesterday. I haven't actually checked the tread of the tyre for a stone though. Kev
It definitely has to be suspension related. Bc it Only happens when turning left. I tested in a parking lot going in circles at slow speed and it would start from medium through full tight to the left. I need a buddy to see if it’s the front or rear. Nothing when I turn right.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Drivetrain, not suspension.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
i had this noise with my L322, turned out to be the lower suspension arms... ... - .- -.
Was that a tick, tick tick noise Stan or just one tick when you turned...?
it was a repeat click Pete..i drove on full right lock and my son walked beside the front off side wheel and diagnosed the lower arm bush.. ... - .- -.
Mine is a repeated tink/click for as long as I’m turning left. Once I straighten out or turn right it stops.
same as you..clicking went when the steering wheel was straight...
Hmm ok. I’ll need to have another set of ears listen for me to determine location 2014 FF Autobiography 5.0 SC
Should be easy to check the arm for play to confirm... |
I suppose once jacked up and pulling on the lower control arm....if it has any play at all it would need rpelaced?
| All times are GMT |
