Home > Technical (L322) > activate starter code......
Page 3 of 4 <1234>
mjdronfield
Found these bits about alarm immobilisation..... just in case it’s the alarm side of things causing issue. Don’t think that would say Code on the dash, but might help diagnosis?
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #602590 2nd Aug 2021 2:19pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Ok ,That's great shall try the activation or deactivation on ignition 1
Yes I am having difficulty opening Rave come to think of it.
Post #602597 2nd Aug 2021 3:23pm
mjdronfield
I don’t think RAVE works with the latest updates to Windows 10, even in compatibility mode.
I’m not sure if there is a link to just a PDF of the Workshop Manual in the wiki.... ie without the automated RAVE bit.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602599 2nd Aug 2021 4:10pm
alfapat
Yeah something isn't right , but not that long since I last used it , but maybe after last update.
Why is it when you have used Rave for years and now I cannot use it now. Can anyone help , I have shifted the compatibility mode to WIN 7 and XP but still does work. Has anyone got a disc they dont need That I can buy and download the latest instr. to try as above in previous post.
Post #602606 2nd Aug 2021 5:43pm
alfapat
alfapat wrote:
Would anyone with their knowledge know if the Sat Nav is controlling the BCM FOR THE CODE , or is the BCM the problem and not accept the code for this interlock.
Emergency Deactivation doesnt work on ign 1 either, so probably the reason is countdown doesn't start.
Post #602611 2nd Aug 2021 7:58pm
mjdronfield
Definitely something strange going on, which is why I’m wondering if it’s ECUs losing comms between each other. Never heard of this before... not helpful I know...
You will need an older PC/laptop to run RAVE mate, there was a thread on here about it. Unless you roll back your Windows 10 to a point it worked, and then don’t do any further updates.
I think there is a PDF available of the Workshop Manual and the Electrical Library, which may go some way to alleviate the RAVE issue.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602613 2nd Aug 2021 8:13pm
mjdronfield
Workshop Manual is here to download as a PDF....
Under the L322 Section....
https://www.landroverweb.com/landrover/pdf...catalogue/
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602614 2nd Aug 2021 8:18pm
alfapat
Bought another Sat Nav and still the same , no countdown!
Post #603309 9th Aug 2021 7:51pm
alfapat
I have put it out there to see if I can find someone locally using Nanocom.
Perhaps it might deactivate this interlock code.
Post #603425 10th Aug 2021 11:49pm
mjdronfield
That sounds like a plan. Can’t help thinking it’s something ECU related rather than sat nav etc. Beyond my knowledge now though I’m afraid.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #603471 11th Aug 2021 12:51pm
alfapat
I need more questions answered.If the Sat nav is required to input a personal code placed by someone in the past , and this code is lost , what is it communicating with , the BCM or the immobiliser. Does the immobiliser when it doesn't recognise the key chip allow the engine to turn but not fire up.
Or does it inhibit the starter altogether.
My point is this interlock code prevents the cracking of the engine as an extra security. Does the immobiliser chip in key do the same . If so then, the immobiliser would be the box to send away and cleared.
Post #603662 12th Aug 2021 10:09pm
mjdronfield
I think some of that is in the screenshots from the workshop manual.
It seems to have got itself into a right mess. The code entered for starting should only last until the car is started once, then it’s gone, ie you have to set it each time you leave the car, so if it’s ever started whilst you’ve had it, it will be gone and not stopping you starting... which is why after the things you’ve tried, I’m thinking ECU. It won’t be the sat nav, that just drives the screen display in the front. Not all cars have sat nav fitted, so the code will not be generated by that.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #603682 13th Aug 2021 9:10am
alfapat
Thank you , seems logical.
Post #603694 13th Aug 2021 11:28am
alfapat
To add then the EWS may also be involved, does that not sit in the centre console beside the gearstick.
Post #603695 13th Aug 2021 11:32am
alfapat
Just realised that is the Ecu immobiliser , but saying that this has a fixed code only recognised by the key , whereas the code entered each time you want can be anything and forgotten after the car starts.
So I'm thinking BCM?
Post #603696 13th Aug 2021 12:01pm
Page 3 of 4 <1234>
