![]() | Home > Technical (L322) > activate starter code...... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7931 ![]() ![]() ![]() |
Found these bits about alarm immobilisation..... just in case it’s the alarm side of things causing issue. Don’t think that would say Code on the dash, but might help diagnosis?
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Ok ,That's great shall try the activation or deactivation on ignition 1
I don’t think RAVE works with the latest updates to Windows 10, even in compatibility mode.
Yeah something isn't right , but not that long since I last used it , but maybe after last update.
Emergency Deactivation doesnt work on ign 1 either, so probably the reason is countdown doesn't start. |
Definitely something strange going on, which is why I’m wondering if it’s ECUs losing comms between each other. Never heard of this before... not helpful I know...
Workshop Manual is here to download as a PDF....
Bought another Sat Nav and still the same , no countdown! |
I have put it out there to see if I can find someone locally using Nanocom.
That sounds like a plan. Can’t help thinking it’s something ECU related rather than sat nav etc. Beyond my knowledge now though I’m afraid.
I need more questions answered.If the Sat nav is required to input a personal code placed by someone in the past , and this code is lost , what is it communicating with , the BCM or the immobiliser. Does the immobiliser when it doesn't recognise the key chip allow the engine to turn but not fire up.
I think some of that is in the screenshots from the workshop manual.
Thank you , seems logical. |
To add then the EWS may also be involved, does that not sit in the centre console beside the gearstick. |
Just realised that is the Ecu immobiliser , but saying that this has a fixed code only recognised by the key , whereas the code entered each time you want can be anything and forgotten after the car starts.
