![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
| SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114
Thanks for that, will try a longer run tonight, fingers crossed it sorts it. |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351
I think you may have an issue as it came on after a run back from Cornwall and has not gone out after 2 runs. Careful as you may run into a red. Grab an iid and you can look at soot levels, egt temps, dpf pressure voltage etc. Without it, running blind.
| wolv79 Member Since: 06 Nov 2019 Location: Burgas Posts: 4
Hello Guys,
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Wolv79,
Hi Mike,
Wolve79,
My iid is now updated to 2765 thanks to Pats excellent service |
Mike
Rob,
| Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342
Hi Dimitar, great write up and brilliant to hear you are sorted.
Many thanks for the explanation!
Dimitar/ Gents.
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Great news!
