Home > Maintenance & Mods (L322) > What to do if your DPF is blocked...
Page 29 of 40 <123 ... 282930 ... 383940>
Baltic Blue
Just a few further points to add to my previous post.
My previous LR independent garage was adamant that it is not possible to do a forced regen when the PO 40 ..etc
EGR fault is showing.
I have now proved him to be wrong… it works perfectly despite the faulty EGR sensor.
Dimitar has also shown that we no longer have to fear getting DPF warnings, even RED ones.
Post #605399 2nd Sep 2021 11:48am
GGDR
This whole area is quite laden with rumours and hearsay. Well-intended mostly.
But now finally there is an easy fix to a bind many of us have been in.
I've been using the separate plug in tool DA-DPF Dongle to do what can now be done on the IID which is a great resolution to this thread I started more than three years ago.
DPFs are great but are an operational blight on the wonderful 4.4TDV8 engine. So it's wonderful Pat has sorted it.
Monitor your soot levels every few weeks people.
And happy regenerating.
. Cheers, Greg
Post #605401 2nd Sep 2021 11:57am
Baltic Blue
Greg,
I will still check my soot level every few weeks as you recommend, but even if you just leave the car to manage the DPF it will give you an Amber alert at approximately 23g , so providing you then activate the forced regen and get the car over 40mph it will bring the soot level down to less than 1g… within minutes. …..Wories over !!!
Post #605498 3rd Sep 2021 4:32pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I was getting persistent DPF messages, both amber and red but the GAP IID tool showed the soot level as zero and so wouldn't force a regen (I have the beta option enabled).
Error messages on IID were the usual P040D EGR sensor Bank A and DPF regeneration failure due to too many attempts.
It finally got to a point that the car dropped in to permanent DPF Full, restricted performance mode.
I eventually managed to get the thing booked in under warranty through the garage that I bought it from and was advised to take it to Woburn 4x4. That was an eventful 60 mile two hour journey!
The upshot after a week was that I got the car back and fingers crossed haven't had a recurrence of the fault.
This is the invoice from Woburn 4x4 (who I would recommend if you're in the area, Andrew's a really nice bloke to deal with);
Woburn 4x4 Service Centre Ltd
Unit 6, Lower Rectory Farm
Mill Lane
Great Brickhill
Milton Keynes
MK17 9FX
VAT Reg No: 806 5238 36
Invoice
Investigate DPF-Restricted Performance Faults:
Ran Diagnostics & Live Data.
EGR Temp Sensor Fault and DPF Soot Accumulation.
Smoke Tested Intercooler and Turbo System.
Intercooler Pipe/Duct Tubes Leaking,
Replace Ducts and Temp Sensor Using Genuine Land Rover Parts.
EGR Sensor Thread Damaged on Removal, Repair Damaged Thread.
LLR052169 Sensor Exhaust £92.71
LLR056285 Duct-Air £26.13 x2
Carried Out Forced Regeneration on DPF 40 minute Road Test
Labour 2.8hrs
VEHICLE : Range Rover
REG: DT09 JUN
MILEAGE : 111,812
Total Net Amount 346.57
Total VAT @ 20% 69.31
Invoice Total£415.88
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #606685 17th Sep 2021 4:31pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Nice to see a company that clearly knows what theyre doing. Straight to the parts required, fitted, tested, job done. What more could you wish for? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #606699 17th Sep 2021 7:33pm
RRDunc
Indeed. I've done 2.5k miles since then, about 800 with the near two tonne tintent on the back and no recurrence.
Happy days!
Post #606700 17th Sep 2021 7:44pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Chaps,
It may be possible to incur a red "DPF Full" alert where this is not preceded by an amber warning.
During lockdown in the early part of this year I had been using a "shopping trolley" in the discharge of my responsibilities as carer to an elderly relative. For reasons I'll not trouble you with I had to stop using the cheap car. Which meant reverting to my FF for the required twice daily short journeys.
Aware of course that I was pushing my luck in respect of DPF failure, options for longer trips to regenerate in the climate prevailing at the time were limited. It might reasonably be argued that I should simply have done this regardless.
Unsurprisingly, I ended up with a red DPF Full alert. And Limp Mode.
I did not however get an amber alert preceding this.
Fortunately, forced regen was successful following transport on a low loader to my Indy.
Since when the shopping trolley has been replaced enabling appropriate adjustment of my (FF) driving habits.
However, my Indy was unable to offer an explanation for the sequence of events in respect of DPF alerts.
I've not found any posts indicating previous similar occurrences.
Anyone have any thoughts ?
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #609585 18th Oct 2021 12:24pm
GGDR
One of the reasons it can go directly to red is a leak.
Usual process: start by checking the donut hoses
. Cheers, Greg
Post #609596 18th Oct 2021 2:56pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Anyone know when GAP will make the DPF function available in a GA release? Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #609605 18th Oct 2021 4:45pm
Baltic Blue
I think you will have to ask Pat to answer your question, but I can happily confirm that I used it again last week to forced a regen and it worked perfectly.
https://www.fullfatrr.com/forum/topic60984.html
Post #609607 18th Oct 2021 4:55pm
Thank you GGDR.
As ever it would appear I have much still to learn.
Post #609632 18th Oct 2021 6:51pm
mrmayhem
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Barolo Black
Range Rover L322 wrote:
Mr Mayhem - can you keep us up as to how your DPF performs now it's been cleaned?
its been fine with no further problems
Post #610839 28th Oct 2021 8:06pm
Caesium
Did a forced regen and it went from 16g down to this in about 15 mins of motorway driving at 60-70mph
 Christian.
Current Cars
2019 BMW X4
or
Post #610849 28th Oct 2021 9:00pm
Baltic Blue
Christian,
One interesting point about your screenshot.
When mine went to below 1g of soot the reading changed to 9g not 0.9g , but when I checked in live values it was actually less than 1g.
Glad you have got it working OK.
Is it stil Beta 2765, or is it on general release now ?
Post #610855 28th Oct 2021 9:17pm
Caesium
Hey Mike.
That’s odd, I’ve noticed the orientation of the iPad/iPhone can do some odd things like what you describe. Perhaps that could be the reason.
Have you reported it as a beta bug to Patrick?
I’m running the beta. Christian.
Current Cars
2019 BMW X4
or
Post #610857 28th Oct 2021 9:21pm
