![]() | Home > Technical (L405) > front knuckle cracking |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
A nyloc nut is meant to be single use even though many people, including myself, re-use them. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8819 ![]() ![]() ![]() |
I had a tube of this on the boat, it is excellent and does what it says, it would certainly prevent the problems on this thread, as I said some pages ago, just add this joint to your service schedule and the arm should outlive the car....
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Is the corrosion that's occurring on the ball joint rather than the bolt? If so, replacing the bolts wont help and in fact it doesn't look like the bolts are failing? |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 133 ![]() ![]() ![]() |
I have not seen any white corrosion on the bolt that secures the top balljoint or in the hole where the top balljoint bolt goes or on the surface of the balljoint, the only build up of the white substance corrosion is on the surface of the hole in the top of knuckle where the top arm balljoint goes.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
I assume that the white corrosion is aluminium oxide. It's interesting that this is only impacting 2015 vehicles in the VIN range 195780 - 228236, as per the Russian video, despite the profile of the knuckle (small head) on earlier 2013-2014 vehicles appearing to be the same
More examples on the Russian L405 forum... http://lr-club.com/index.php?showtopic=157106 Kev
Morning kev
Yeah, you need to sign in too see the thread Jon. If you use Google Chrome, it will auto translate the Russian. I have a look on that forum every now and again and the post caught my eye.
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 159 ![]() ![]() ![]() |
HI
Just noticed its the same as the one you tried but it works for me and you should get an automated responce that says they will reply within 2 days. |
Update:
I went throught the procedure with DVSA and they collected the knuckles from both sides damaged and undamaged for testing but nothing from them yet, i refused to drive it without the other side being repaced as i got away with the first faliure and it was not going to get another chance of getting me at full speed as the first one was at about 5 mph, i have twice been told by JLR Customer Experience Centre that they can't cover the cost of my repair as it was not done at one of there franchises but it could not be done at there franchise as there was no space when the AA man called colchester Land Rover to book it in which was not a surprice as they had refused him taking a 2 month old L405 the day before due to workload.On JLR Customer Experience Centr 2nd refusal to cover the cost of repair which was 2 days ago i advised them as of the time and date of my email i was advising them that there was a safety issue with the knuckle at the point at which the top balljoint was clamped on all 2015 Range Rover L405 and i was then told its been raised within the Jaguar Land Rover Customer Solutions Team and a Solutions Executive will contact me in order to discuss further within 72 working hours but i have not heard anything yet and it does give them untill 14.06 15/11/2021, i would be very interested to hear how you get on as the person that started this topic was also refused and yours sounds the most positive yet . |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
Do not hesitate, go straight to VOSA with this. They will investigate and if its common force JLR to do a recall. That might well save someones life.
