Home > Maintenance & Mods (L322) > Locked out of my 2011 RR Vogue
Page 2 of 3 <123>
GraemeS
Australia
The starter motor solenoid battery connection is easy to get to providing the vehicle can be jacked enough to get under.
Post #609205 14th Oct 2021 9:00pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
it is actually exposed and easy enough to access the starter from behind the driver side wheel, i did it whilst trying to correlate voltage drop from battery > starter then battery > relay/trigger> starter
On a separate note, what about the physical key? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #609215 14th Oct 2021 9:44pm
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Still not opened getting ready with big hammer!
Baltic Blue, getting just over 12v across socket terminals with volt meter so assume there ok.
Haylands, front side are laminated, rears look std glass. Does not look like I can get to bonnet release throu grille as I have latest front end, everything has been covered over nothing visible.
Merchy, have just tried booster on starter terminals, nothing unlocking.
Do any of you know where I can get an untinted std rear o/s door glass?
Thanks again for all your suggestions -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #609261 15th Oct 2021 12:27pm
kevinp
I've just read that when you turn the key in the door you have to pull the handle at the same time. Worth a go.
Post #609274 15th Oct 2021 2:12pm
Giffer2018
kevinp, yep tried that in various combinations -----------------------
Post #609295 15th Oct 2021 4:47pm
Others have opened the bonnet by removing the left (front) inner wheelarch (after removing the wheel) and then gaining access (with tools) to the two bonnet release cables/mechanisms. Could be a battery disconnect procedure may be in order... .
Post #609297 15th Oct 2021 5:17pm
Merchy
Just remembered my similar condition - Car Lock smith?
I was away at sea, a week prior to my return home my daughter tried to open fatty to check it would start / charge battery. She could not open it as it was dead as a doornail. I Was not here so I don't have full details. But no one could get into the car by ANY method............ANSWER...... she called a car locksmith, who got into it with no damage caused to the car.
Worth trying before using the big hammer, sorry I don't have more details, one thing I can remember is that daughter said the lock smith did not want people watching as he got into it which is understandable.
Hope this helps, probably cheaper than new glass, thumbsup:
Edit - Just seen the above post, but you would need the locking wheel nut tool, which I assume is in the car Big Cry
Post #609298 15th Oct 2021 5:23pm
Giffer2018
Joe90, Merchy, Yep locking wheel nut is in car together with Jack.
Spoke a local locksmith said could'nt get in without causing damage.
I think I have found a new replacement battery for the duff one, Exide 019 AGM EK950 for £120.
Also ordered a second hand rear door window in case I have no option than to break in. -----------------------
Post #609316 15th Oct 2021 8:20pm
Merchy
An addition to my post above, I forgot, at the time the cable for the outer door handle was broken (Drivers door ) just spoke to daughter, she said, quote -
'The locksmith did it the old fashioned way, he pulled the door frame outwards to get a wire in and a very small pad to keep some space, to get the wire to the inner door handle, obviously the car was locked shut, this was on a 2006 car There was zero damage to the car. May be worth a try the same way ?
Edit -
Bit more info from my daughter - apparently, the lock smith used a very small plastic protected lever on the top of the door frame, right at the rear of the door, next he slid in a very small inflatable plastic bag, slightly inflated it, then used a very thin tool almost like wire to pull on the inside door pull and the door opened. He did say there was a possibility of damage and that he would go ahead, if he was not responsible if any damage was caused, she bravely said 'go for it' Shocked But it worked a charm Thumbs Up
Post #609318 15th Oct 2021 8:27pm
mjdronfield
I’m not sure that’s gonna work if the car is double locked…. Perhaps the only thing to go for is the bonnet catch, might be hard to pull though.
I’m also not sure if the open tailgate button on the dash might work….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #609324 15th Oct 2021 8:48pm
GGDR
AA are pretty good at breaking in to cars.
. Cheers, Greg
Post #609326 15th Oct 2021 10:06pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
There is a way to open the boot lid and get in. DO NOT smash a window and DO NOT have a locksmith destroy your door lock barrel.
pm sent
Post #609334 16th Oct 2021 6:25am
mjdronfield
Think he’s tried that already….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #609353 16th Oct 2021 10:41am
vs322
Neither will work on a superlocked / double locked car. Ask me how I know Whistle
But the trick I'm referring to, works every time and is a good insurance policy to know about it...
Post #609364 16th Oct 2021 11:26am
mjdronfield
Hopefully he can use it to get in then. Then carry on sorting potential battery issues from there.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #609365 16th Oct 2021 11:40am
Page 2 of 3 <123>
